3 bottom plow purchase advice
   / 3 bottom plow purchase advice #21
jagyzf said:
I don't know why they would pull harder. I could see having to down size though based on weight, having double everything has to be heavy.
The weight is what was mentioned as to it pulling harder.
Jagyzf,
Thanks for the pictures and the education.
jagyzf,
What does the link actually control? It looks like with the tire down the link is the adjustment for depth control.
   / 3 bottom plow purchase advice #24
jagyzf,
Which link the top link on the 3 pt? Or the linkage that goes to the back wheel?
Which plow are we talking about? I posted a few.
jagzyf,
sorry, I knew which plow I asked about and apparently I must have thought you had ESP..ha.
It was the IH740 and the linkage I was wondering about was the one from the rear of the plow that goes from the tire assembly to the front of the plow
correction...IH710 was the plow in question
An old timer told me once when I was a kid..
"put brain in gear before engaging mouth"
I think today it would likely be...
"put brain in gear before engaging fingers"
JasG,
thanks for link to the oliver plow book,it looks it should answer a ton of questions
   / 3 bottom plow purchase advice #30
Will a 2-3 bottom plow work well for planting food plots?:confused:
2017 International WorkStar 7300 Rosco Maximizer 3B 1,900 Gallon Asphalt Distributor Truck (A52377)
2017 International...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
2017 FORD F550 XL SUPER DUTY BUCKET TRUCK (A51406)
2017 FORD F550 XL...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
