What did you do to your tractor today?
   / What did you do to your tractor today? #161
I bought an OLD Dearborn 10-1 2 bottom plow, spent all day cleaning it up and the next day plowed my 1.5 acre lot for the first time. Put my new B3000 to the test for sure. I was very impressed with the results! I have never actually "plowed" before and read up on it and still made some mistakes but it ended up looking nice. Glad I didn't read it takes a 45hp min. to pull this 16" two bottom plow!! haha
Once I finally got it set it really did do a nice job of plowing. I had the FEL loaded with dirt or I could have never moved it. There are tricks to plowing, I have a new appreciation for those old farmers who used to plow for 3 weeks straight. It's a rough job for sure.
   / What did you do to your tractor today? #162
Over the weekend I finished building a fabric carrier for the loader QA. Then out the tooth bar on the bucket and started removing topsoil for a new driveway. :):cool:
   / What did you do to your tractor today? #163
I helped my Uncle, almost got stuck while trying to dig some ditches for him to divert some water for a garden spot. The ground hasn't seen a machine in 20 years or more, the whole area is like a swamp. The worst part was busting a hydraulic hose on the FEL trying to get out. Luckily my cousin has a hydraulic and machine shop. LOL, next door to Kubota. It worked out good and we were up and running in about and hour.
wow that's some mud! :shocked:
   / What did you do to your tractor today? #165
What did I DO to my tractor? I greased all the fittings I could find on my JD 2210 - now, about the U-joint almost impossible to get to fittings - I still have to figure out how to get to those!
you need to get what they call a needle greaser it looks like a pencil with a grease fitting on the end you push it in to the little ball at the end of the grease fitting in the U joint :thumbsup:
   / What did you do to your tractor today? #166
i put a new cutting edge on my bucket B1750 kubota and welded up the split in it thats what i get for letting my sons use it lol 4 hr of fun welding :thumbsup:
   / What did you do to your tractor today? #167
I drove to Missouri looking for a bargain on a 55hp & 95hp cab & air 4X4 with R-4 tires & heavy duty front loaders with rootrake grapples & buckets & shuttle drive and a bargain on a Woods BW180 with chains & foam filled aircraft tires ( best so far $10,500 ). Who knows which tractor is the best deal? Creekman@wildblue.net
   / What did you do to your tractor today? #168
I bought it as 'good' 70thousand miles and running great when taken out motor
Put it in my Land Rover and it would only fire properly on 3 cylinders
It's a 200 tdi (2.5 4 cyl Turbo Diesel)
Took motor out and found a bent conrod on No 4:mad:
Some people tell lies when selling motors, I wouldn't but some do unfortunately
Land Rover 90 ( defender) 1990
I had a "P" reg 90 turbo truck cab ..wonderful thing that was
   / What did you do to your tractor today? #169
Bought hydro/trans filters at a dealer today. They look a bit differently but part number is the same.
It's curious to compare the price. I paid 103.65 USD for both (VAT included).
   / What did you do to your tractor today? #170
Were they gold plated !!!
2006 Mercedes-Benz R-Class AWD Van (A55758)
2006 Mercedes-Benz...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
SDLanch SDLLM500 (A53316)
SDLanch SDLLM500...
2015 Ram 2500 4x4 Crew Cab 6FT Flatbed Truck (A55788)
2015 Ram 2500 4x4...
