JD 3032E Exhaust Fumes
   / JD 3032E Exhaust Fumes
Short throw, thanks for the pics.
Does the welded exit on the muffler go straight out? Hard to tell in pic if that elbow is removable.
Sure looks like it may work. Mine has 1.75" od tubing.
What model tractor do you have?
   / JD 3032E Exhaust Fumes #12
yeah. it goes straight out. that elbow is clamped on there. i have 2012 3520 tractor. let me know if you need more pics or measurements
   / JD 3032E Exhaust Fumes #13
Our little Ford had a forward facing exhaust and looked a little lawn mowerish so I made a verticle stack out of some old pipe
looks more like a tractor now and no fumes:)
Nice restoration and you got to love the porcelain complexion of those English gals!
Shortthrow, is that tubing 1.75"? If so, I will order the kit for mine.
   / JD 3032E Exhaust Fumes #15
I just went and measured the tubing that the elbow slips on. The outside diameter read 1.75". The slip on elbow going into exhaust stack and the stack itself is 2".
   / JD 3032E Exhaust Fumes #16
dlantho,
Please keep us updated on this project. Also any tips on cutting through the hood will be appreciated. I am very interested in this and will be eager to see the outcome.
Thanks,
Steve
   / JD 3032E Exhaust Fumes #17
She's a haidressers dummy head with a body made from foam. Very realistic at times, too realistic at times, I have to give her a squeeze to make sure she isn't real.:laughing:
I ended up removing the factory ex. pipe. Took the pipe and a few measurements to my local muffler shop. Came back with the set-up in the pics. Bolted on & wow! Night & day difference on the fumes. No problem openeing the hood. Cost $100.
Thank you to all for your valuable advice!
   / JD 3032E Exhaust Fumes #19
Nice job, I like that better than going thru the hood.:thumbsup:
   / JD 3032E Exhaust Fumes #20
Looks good! Is this 1 piece or 2, with a U attaching to the existing pipe and the multi-bend riser for the rest? Is the pipe supported any way by the FEL frame? Any vibration against the hydraulic lines of the FEL? Thanks.
Steve
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
7046 (A50322)
7046 (A50322)
2022 Heli Forklift (A51573)
2022 Heli Forklift...
2008 Chevrolet Trailblazer SUV (A51694)
2008 Chevrolet...
UNUSED AGT SDA 140W WHEEL LOADER (A51247)
UNUSED AGT SDA...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
