I have found that if you are driving fast when the trailer starts coming apart, you all ready got a good head start.![]()
those tires are rated for 1750 pounds a peice. I feel that rating is for long term highway use and you can probably load way more than that if your driving 35-40mph for a distance of 4 miles. I went back for another load today and put about another half bucket one. Next time im just gonna fill all the voids. Cant go much higher cause the dirt spilling out on the road.Out of curiousity, what are the tires rated for? They look to be holding up well!
I'm far from the safety police as I don't think a little overloading is that bad when you consider the safety margain the engineers put into that trailer. Plus I'm sure you have the recommended 20% tongue load which only puts you over by 200 lbs. :thumbsup:
I don't recommend it but have overloaded a trailer or two a couple of times.
At least you have the right truck! ;-)
Yep, I've carried a few loads that where over the weight rating too, and did it with a truck that was capable of the extra weight. Now if you ask me, I will tell you to get the right trailer for the job. Only because I know my limitations and driving ability, and don't typically know of the person's asking.
I've driven an over-loaded trailer before- never again!
If you *do* get involved in an accident(even if not your fault), you'll be in deeeep. Your insurance won't cover you, and your estate is exposed for liability.
You could have doubled your load by filling up the truck bed along with the trailer.
That's what I was going to mention too.
I've hauled a fair bit in my 5x8 utility trailer. But, I have hauled a lot more in my 3/4ton Ram. The tires etc are made to handle the load on the truck.
I'll admit though, it is much easier to unload the trailer than shoveling out of the much taller 4x4 truck(even though it is only stock height, no lift or anything...)
those tires are rated for 1750 pounds a peice. I feel that rating is for long term highway use and you can probably load way more than that if your driving 35-40mph for a distance of 4 miles. I went back for another load today and put about another half bucket one. Next time im just gonna fill all the voids. Cant go much higher cause the dirt spilling out on the road..........
