LA513 curling cylinder
   / LA513 curling cylinder #1
Dennisr
Goodlettsville,TN
L3130
How hard is it to replace the seals in the cylinder ? I had it repaired by dealer two years ago and it is leaking again. Is there a dealer who sales the kit ? Can a new or rebuilt cylinder be purchased ?
Thanks
Dennis
   / LA513 curling cylinder #2
Thanks
Dennis
What are you doing that you have to reseal the cylinder after two years of use?
It's generally not a hard thing to do. Removing the rod gland nut sometimes takes a special pin wrench but once that's off it comes a part really easily. Make sure you drain it first or it will get messy. Get your parts off the dealer or go to a hydraulic specialty shop and they should be able to match the piston and gland seals. They might even have better than OEM parts.
   / LA513 curling cylinder #5
I use it for lite duty. It leaks more when fully extended. Could that be a bent rod ?
Could be. Something is tearing up your seals.
Mine on my LA463 loader is 6 years old. Still not even so much as a drip.
Is this thing stored outside??? Got any rust or pitting on the rods themselves?
Cylinder looks new , just leaks.
   / LA513 curling cylinder #7
My LA853 curl is also leaking (internally). Bucket will droop from level to fully down in maybe 1-2 minutes. Just turned over 400 hours. It may be the valve, I haven't yet tried swapping the hoses. I have abused it some, using the tooth bar as a rock rake and back-dragging a lot. I figured that a decent hydraulic shop for seal replacement was the simplest option.
   / LA513 curling cylinder #8
One of the dirty little secrets of cyl repairs lasting is "Fit & Finish"
If it has a poor fit (sloppy gland) or poor finish (pitted or scored chrome) then the seals will not last
Just throwing in a seal kit IMHO is not rebuilding a cyl.....carefull polishing, measuring, and inspection uncovers defects no one else will see.....just a word to the wise....:cool:
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A51222)
2019 BIG TEX...
Craftsman YTS 3000 42in. Riding Mower (A49346)
Craftsman YTS 3000...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
JOHN DEERE 544G (A50854)
JOHN DEERE 544G...
