LA513 curling cylinder
   / LA513 curling cylinder #1
Dennisr
Goodlettsville,TN
L3130
How hard is it to replace the seals in the cylinder ? I had it repaired by dealer two years ago and it is leaking again. Is there a dealer who sales the kit ? Can a new or rebuilt cylinder be purchased ?
Thanks
Dennis
   / LA513 curling cylinder #2
Thanks
Dennis
What are you doing that you have to reseal the cylinder after two years of use?
It's generally not a hard thing to do. Removing the rod gland nut sometimes takes a special pin wrench but once that's off it comes a part really easily. Make sure you drain it first or it will get messy. Get your parts off the dealer or go to a hydraulic specialty shop and they should be able to match the piston and gland seals. They might even have better than OEM parts.
   / LA513 curling cylinder #5
I use it for lite duty. It leaks more when fully extended. Could that be a bent rod ?
Could be. Something is tearing up your seals.
Mine on my LA463 loader is 6 years old. Still not even so much as a drip.
Is this thing stored outside??? Got any rust or pitting on the rods themselves?
Cylinder looks new , just leaks.
   / LA513 curling cylinder #7
My LA853 curl is also leaking (internally). Bucket will droop from level to fully down in maybe 1-2 minutes. Just turned over 400 hours. It may be the valve, I haven't yet tried swapping the hoses. I have abused it some, using the tooth bar as a rock rake and back-dragging a lot. I figured that a decent hydraulic shop for seal replacement was the simplest option.
   / LA513 curling cylinder #8
One of the dirty little secrets of cyl repairs lasting is "Fit & Finish"
If it has a poor fit (sloppy gland) or poor finish (pitted or scored chrome) then the seals will not last
Just throwing in a seal kit IMHO is not rebuilding a cyl.....carefull polishing, measuring, and inspection uncovers defects no one else will see.....just a word to the wise....:cool:
ASSET DESCRIPTIONS & CONDITION (A51219)
ASSET DESCRIPTIONS...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A51222)
2016 VOLVO VNL300...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
