nickel plate
This hydraulic angle kit looks to be fairly easy to duplicate for less than the $461.00
that York wants. The cylinder appears to be a "Chief" so that's commonly carried through TSC and other outlets, hoses and tips are no problem either. My York RI 8' rake is exact to this sales photo with the exception that mine has the standard mechanical adjustment bar but the mounting tabs are the same but York Modern offers up no cylinder specs as far as I know. The rake's two attachment plates are of different thicknesses so the cylinder's base clevis fork needs to have a 1" opening and the rod clevis fork needs to have a 3/4" opening or both just at 1" as in the photo there looks to be some play in the rod's clevis fork.
Right now I hope someone has this kit and can help me with the cylinder size and stroke or I can attach it up and try calcing the rake's swing angles. Any thoughts on how to correctly do that and match it to a cylinder? What diameter cylinder would work the best? My tractor has 1/2" remotes, what would be the minimum size hose I could use?
