100+ HP Kubota - any good?
   / 100+ HP Kubota - any good? #11
Your 125 must be the economy if it sold for less the the 125 Kubota. The 140 is a better choice if they are loaded up because of the performance issue, we have hills here as well! Your 125 probably has a total load configureation of less then 20,000 lbs when used correctly so sometimes the numbers will get you into trouble. The 140 also runs a heavier front axle I believe getting up to a class five. Balance is the most important part when operating a tractor.
As far as hitch lift and loader capacities I go by break-out force. That is about the only thing you will ever feel is when it won't do it! That is unless you know your dealing with pallets at x lbs.
I have the 125 Pro. It was also cheaper than the comparable JD.
   / 100+ HP Kubota - any good? #13
We have a M135X I really like it a lot there are some things that I don't like.. the instructor seat it isn't that comfortable and the 3 point hitch needs to be stronger it is already great but it could be better, but overall the machine is great
Here is a picture of it
   / 100+ HP Kubota - any good? #14
Some of the points that are being commented on seem in line with the introduction of the new Grand X series just announced in Feb. Youtube has a couple of videos from one of the bigger farm shows and they go over the new features:
- larger more roomier cab ie" 10" wider, 7" taller
- larger more comfortable second seat
- panoramic view
- more modernized
- standard 24 speed transmission
- increased 3PH lift capacity
- etc.
So it looks like Kubota took note and has addressed a lot of the concerns / issues.
   / 100+ HP Kubota - any good? #15
there is a 3pt lift assist kit that can be added if this is really a problem for you.
   / 100+ HP Kubota - any good? #16
Thanks but it's not a huge problem
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2019 TIGERCAT 234B TANDEM AXLE DE LIMBER (A54607)
2019 TIGERCAT 234B...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
