100+ HP Kubota - any good?
   / 100+ HP Kubota - any good? #11
Your 125 must be the economy if it sold for less the the 125 Kubota. The 140 is a better choice if they are loaded up because of the performance issue, we have hills here as well! Your 125 probably has a total load configureation of less then 20,000 lbs when used correctly so sometimes the numbers will get you into trouble. The 140 also runs a heavier front axle I believe getting up to a class five. Balance is the most important part when operating a tractor.
As far as hitch lift and loader capacities I go by break-out force. That is about the only thing you will ever feel is when it won't do it! That is unless you know your dealing with pallets at x lbs.
I have the 125 Pro. It was also cheaper than the comparable JD.
   / 100+ HP Kubota - any good? #13
We have a M135X I really like it a lot there are some things that I don't like.. the instructor seat it isn't that comfortable and the 3 point hitch needs to be stronger it is already great but it could be better, but overall the machine is great
Here is a picture of it
   / 100+ HP Kubota - any good? #14
Some of the points that are being commented on seem in line with the introduction of the new Grand X series just announced in Feb. Youtube has a couple of videos from one of the bigger farm shows and they go over the new features:
- larger more roomier cab ie" 10" wider, 7" taller
- larger more comfortable second seat
- panoramic view
- more modernized
- standard 24 speed transmission
- increased 3PH lift capacity
- etc.
So it looks like Kubota took note and has addressed a lot of the concerns / issues.
   / 100+ HP Kubota - any good? #15
there is a 3pt lift assist kit that can be added if this is really a problem for you.
   / 100+ HP Kubota - any good? #16
Thanks but it's not a huge problem
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
FIRESTONE 420/85R30 TIRES WITH 8 LUG WHEEL - WHEEL FITS TM SERIES NEW HOLLAND (A52748)
FIRESTONE...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
2015 JLG 2632ES 26FT Electric Scissor Lift (A50322)
2015 JLG 2632ES...
