Tarp for Wood Piles???? What do you use thats black?
   / Tarp for Wood Piles???? What do you use thats black? #11
I cover the tops only, and leave the sides open for air to move through the stack. I do place most pieces bark side up. I don't cover all my wood, only that which i expect to burn in the next few weeks, i don't have room on the porch to store much wood, only a couple days worth. When we are burning wood i stock it every chance i get
   / Tarp for Wood Piles???? What do you use thats black? #12
I cover my woodpiles after a long dry stretch and definitely towards Fall. You can get used lumber covers from your local discount Lumber place..Menards, Home Depot, etc just for asking. They work well for a couple of seasons.
   / Tarp for Wood Piles???? What do you use thats black? #13
Bark side down for the bottom row.
I don't cover mine either.
   / Tarp for Wood Piles???? What do you use thats black? #14
It's obvious none of you live in the Puget Sound Region of WA State. We don't have the cold winters to freeze dry it, but lots of rain to soak it up. We cover only the top and about a foot down the side to ventilate. Full tarping here is guaranteed early rot, slugs, and other bugs. We cut, split, and stack it in the summer/early fall and cover before Oct. Works well. You will see as many ways of covering as there wood piles.
Ron
   / Tarp for Wood Piles???? What do you use thats black? #15
Never a tarp here either. If anything, just an ole sheet of tin on top of the pile. Tarps trap any moisture and help mold/mildew grow.
   / Tarp for Wood Piles???? What do you use thats black? #16
I keep mine under roof now. Before the roof, I covered the pile to keep the blocks from freezing together & avoid bringing ice into the house! ~~ grnspot
   / Tarp for Wood Piles???? What do you use thats black? #17
I use the holz hausen (Build a holz hausen to dry firewood by Doug Fluckiger Issue #132) but I also came across a german way to stack firewood stack rebuilt german style
I do put them on pallets to keep them off the ground. When doing green wood I will leave them in a pile for a few weeks and then stack. I like this method because 1. it looks nice, and sheds snow, 2. you can put smaller rounds in the middle, this makes it much more stable.
I find I can also store a lot more wood in the same space.
I just throw a tarp over it once snow is on its way.
   / Tarp for Wood Piles???? What do you use thats black? #18
I stack between trees and use 15# roofing felt. It covers the top, is water proof and reasonably priced. Oh and it is black also.
MarkV
Thanks for the ideas fellas. didn't mean to open up a discussion on to cover or not.
where I stack my wood - I really need to cover to aid in drying.
Will look into to the felt and the balck visquuen....Thanks again
   / Tarp for Wood Piles???? What do you use thats black? #20
Now that is a great idea.
2014 Kenworth T370 Single Axle Dump Truck, VIN # 2NKHHM7X6EM419999 (A57453)
2014 Kenworth T370...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2020 CATERPILLAR...
8' Snowbox With 2' Extension (A55272)
8' Snowbox With 2'...
2004 Kubota R520 S (A57148)
2004 Kubota R520 S...
2000 Club Car Electric Cart (A56859)
2000 Club Car...
WHITFIELD TREE PLANTER FL8612172 (A58375)
WHITFIELD TREE...
