Ideas for Kubotas next BX lineup?
   / Ideas for Kubotas next BX lineup? #31
Don't add "more."
Add "better."
Refine what it has instead of adding more "stuff."
Bruce
   / Ideas for Kubotas next BX lineup? #32
if they are saying next years models will be the pollution free models or will be electronically controlled there might be a replacement or big modifications to the current bx25 due to the fact that there is no room under the hood to add anything...anybody???
   / Ideas for Kubotas next BX lineup? #33
snip
if you were at the table when the new BX or "Max killer" tractor was designed,
snip
I must correct you, the Kubota "MAX" has been around for over one year.
Here is the logo ... and no, it is not home made nor photochopped.
CLICK HERE and you can find a Video of Kubota MAX tractors as well.
I call it like I see it, that video is OVER a year old too! Nice looking
tractors the Kubota MAX is indeed! :D
   / Ideas for Kubotas next BX lineup? #34
Honestly with the experience i have had on a BX24, Kubota needs to do something different underneath the tractor. They need to make the hydrostatic fan easily removable from underneath the tractor, plus have an effective shield that will actually protect the fan for those who run their BX's in the woods or brush. I also would do something about the hydraulic filter, quite frankly it is very exposed to the terrain underfoot and a protruding rock or small stump hidden by brush could easily destroy the filter. And finally, I would do something different about the first fuel filter in the line, it is kinda a pain to replace and who wants to remove their mower deck to replace a fuel filter? That's my :2cents:
I may own two Deere's but that doesn't mean I have never driven a Kubota. ;)
   / Ideas for Kubotas next BX lineup? #35
... eeeeh. a good sales person should not sell any Subcompact to someone who wants to crash though the woods with it. You simply don't have the ground clearance to do that safly. A skid plate would help, but there is still a whole host of things you can destory that would not be covered.
   / Ideas for Kubotas next BX lineup? #36
Needs an intergrated tool box for stuff :thumbsup:
   / Ideas for Kubotas next BX lineup? #37
That's certainly true, but one rogue stick in the yard can cause more damage than should happen on something that costs this much...I shouldn't have to buy skid plates to protect what Kubota should have protected on their own.
   / Ideas for Kubotas next BX lineup? #38
The thing is "Is it a Tractor or a Toy?"
Kubota (and the other SCUT manufacturers) sell the BX as a tractor. And if it is a tractor it should have underside protection. I dont like the exposed fuel filters, fan and hyd filter on mine. I have contemplated making a skidplate, but i dont know if it will even be possible to have a skidplate and the MMM installed. The gearbox on the MMM really gets up there when the deck is lifted. I use mine like the tractor it is..
If it's a glorified lawnmower, then yeah, leave its soft underbelly, but you better modify your advertising.
I bought mine because a larger tractor wouldnt "fit" my property and all my uses. Kubota should at least offer a factory skidplate kit that takes into account the clearances for the MMM.
Oh and do something about the location of the steering ram... could you think of a more dumb place to put it? I think one seal is already leaking on mine:mad:
   / Ideas for Kubotas next BX lineup? #39
Bro-Tek makes one but when the MMM is installed it acts as a skid plate. :)
   / Ideas for Kubotas next BX lineup? #40
1. Drive over MMM (as an option)
2. Foldable ROPS on all models (standard)
3. Hydraulic top link (as an option)
4. Independent TPH and mid elevation controls
2019 Nissan Sentra (A51694)
2019 Nissan Sentra...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53473)
Ditch Witch 6510A...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
Honda Pressure Washer (A53117)
Honda Pressure...
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
