Kinco KMG38 Sickle Mower
   / Kinco KMG38 Sickle Mower #11
I have the manual, and have scannned it into a pdf file. I have the 4 hp Briggs engine, and can not replace the dual horizontal/vertical drive engine. Trade you a copy of the manual for all model, serial and any other ID numbers on your tech. engine- maybe I can repower with a similar model. Manual covers disassembly of blade & all other adjustments. Manual available to all others interested, just keep my list of equipment in mind 'cause somethings always needs repair & I'm always looking for parts, dismantlings, etc.
I just bought a KMG-38 with a 4 hp Briggs engine. Could you please send me the pdf of the manual for this mower. my e-mail address is haroldp5@earthlink.net.
Thank you,
Harry Prather
Quilcene, WA (on the Olympic Peninsula)
   / Kinco KMG38 Sickle Mower #12
Thank you,
Harry Prather
Just to let you know that the last time he's been here was 9-10-10... he might not be back. Maybe a one time poster... If you click on his name, you have an option to send him an e-mail... you might want to try that.
   / Kinco KMG38 Sickle Mower #13
I have a KINCO KMG38. I am missing the part that bolts to the sickle bar and actually moves the bar back and forth. I think I am going to have to fabricate this part, since I ordered one from Jari and it is not even remotely correct.
Could someone please send me a couple of good close-up pictures of this part, so I know what I am trying to fabricate? I would really appreciate it.
Thank you,
Harold A. Prather
haroldp5@gmail.com
   / Kinco KMG38 Sickle Mower #14
Hello again,
On the underside of the mower there is a rod going from the center crossbeam toward the operator, with a hole in one end that might be attached to a spring.
How, and to what, should this rod be connected?
Thank you,
Harold A. Prather
haroldp5@gmail.com
Quilcene, WA On the Olympic Peninsula
   / Kinco KMG38 Sickle Mower #15
Hello,
I'm new to this board... lots of good stuff here. I recently acquired a Kinco KMG 38 walk behind sickle mower. I found some info on the manufacturer, and gave them a call, but there facility in St. Paul, MN was still closed for the winter. I'd like to get any available owners/service/parts manuals that might be available. If anyone has this info, I'd gladly pay for a copy of it.
On a related topic, the tires are 4.10/3.50 - 6. They're shot. I've found some Carlisle 4.10 - 6 lugged tires. What is the difference between a 4.10/3.50 - 6 and a 4.10 - 6 ?
Thanks in advance.
How much did you pay for it and what condition was it in?
   / Kinco KMG38 Sickle Mower #16
Thank you,
Harry Prather
   / Kinco KMG38 Sickle Mower #18
I don't remember exactly what I paid for it, but it was just under $200
The mower itself was in vary good condition, but I needed to replace several sickle bar blades and some moron had welded the bar motivator bracket to a couple of broken blades.
Hope this answers your question
haroldp5
   / Kinco KMG38 Sickle Mower #19
I have Kinco KMG38. The sickle and the shaft coming from the engine has come apart. I have no idea how it is hooked up., no bolts or bolt holes, I am at a loss to figure this out. I would appreciate if someone could send me a picture or tell me how it is hooked up
Thank you
   / Kinco KMG38 Sickle Mower #20
I'll remove the top cover and take some pictures for you tomorrow afternoon.
haroldp5
Thank you
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2016 VOLVO EC380EL EXCAVATOR (A51246)
2016 VOLVO EC380EL...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
