Dump Trailer Tool Box
   / Dump Trailer Tool Box #11
That's a great idea! How well does it hold everything in there? Does the bed bottom seal the compartment?
The bottom is expanded metal, I added a lil expanded metal section
along the top so it is impossible for anything to fall out. It is like a clam,
when the top closes it makes a box so nothing can fall out.
There is a TON of room under a dump trailer...
   / Dump Trailer Tool Box #12
Mine's a deck over so has some room under it but the piston location may be in the way, I may need to break out the welder...
   / Dump Trailer Tool Box #13
Dmace indeed, you and everyone else should capitalize on my idea.*
When I thought of it, it was an epiphany, I mean the light bulb didn't just
come on, it came on and blew up, and I instantly started making it. It
was fun to do knowing how cool it would be to stow my stuff all related
to my tractor in a protected secure area. :licking:
I am SURE others have done it but they didn't share there idea w/ this
list now did they? My way is called "Paying It Forward" and I will
continue to do so (unless I see a potential to make a buck :laughing: ) even then
I will ............... :D
Here are a few more pics. NOTE where I point. That is the upper part of
the clam shell that disallows any of my possessions to jump out when
I hit a bump. When the dump portion closes it creates a "Box" so my
stuff, remains "my" stuff!
I hope others see this and build on my idea and SHARE their builds
with others here on this list.
I also had a thought to make a spare fuel tank in there along w/ a compressed air refillable tank.
I need a spare for my trailer, anyone close got one? :)
* I mean if you are refering to my idea anyways...
I am currently in negotiations w/ a guy who has a nice Warn Winch that
I want to add to this trailer. THAT is a whole new thread when it happens
and it will be the CremDeLaCrem' I say! HA! :laughing:
I have one of those .... just didn't catch the fancy ininials description. Not a text'r ...... does it show ?
   / Dump Trailer Tool Box #17
If anybody tricks out there dump trailer undercariage post up pics here!
Lets see the work! Let the carnage begin! :D I really need to add more to mine. Right now I am rebuilding that 554 bearcat and fabricating theft
deturant devices for backflow valves x 4 all custom.
Solved the battery / hydraulic pump storage box. I built one out of 20 guage sheet metal. I could not find a prebuilt unit with the right deminsions I have that would look like it would belong. The oil reservoir and pump are 16" tall and I needed this distance to make everything fit. It turned out fine and for less than twenty dollars in material. I had enough left over to make a mid mounted mower transition to eight inch flex hose for a lawn vacuum I am building.
   / Dump Trailer Tool Box #20
Love it when a plan comes together! Good job! I started making an addition
to the under-bed storage on my trailer yesterday. This one will really holds
the goods! Pics maybe tomorrow...
500BBL WHEELED...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56435)
LIKE NEW 2023...
American G-Model Pump Jack (A56435)
American G-Model...
2019 Dodge Charger (A56859)
2019 Dodge Charger...
24 Bucket attachment (A56857)
24 Bucket...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
