Dump Trailer Tool Box
/ Dump Trailer Tool Box #1
Agent Blue
Platinum Member
Finished my 12' dump trailer and need to build or buy a container to hold straps, battery, and electric pump. It came out as an odd shape, 27" at the rear to a front taper approx three feet in width. Anyone have any ideas on construction ( tin or aluminum ) and needed features?
/ Dump Trailer Tool Box #2
Lots of ideas: :)
I found those pictures also. The problem lies in the limited space I have to place one. I am leaning towards sheet metal bending the structure to the size of the V hitch C channels. I have acess to aluminum but would have to bolt it as I don't have a tig welder.
/ Dump Trailer Tool Box #5
Harbor freight sells (or sold) two different size boxes I used this one on my ATV trailer. Locking Steel Trailer Tongue Box
it might be big enough for the pump and battery. It is close to the size of the box on my dump trailer.
You could look it over for details on how to build or buy it.
/ Dump Trailer Tool Box #6
I built an expanded metal compartment under the bed between the
frame rails...works WELL for me. Heck I am going to expand it and make
a compartment for my tarp as well as a broom and other things
when other projects are finishe up.
/ Dump Trailer Tool Box #7
That's a great idea! How well does it hold everything in there? Does the bed bottom seal the compartment?
/ Dump Trailer Tool Box #8
When you build the tool box, keep in mind if you ever need to use a WD hitch.
/ Dump Trailer Tool Box #9
Take a look at the Bri-Mar trailers. My uncle has one and it has a tool box and spare tire all mounted under the dump bed like the one pictured above.
Chris
Artisan that is a great idea for a tarp, broom, straps, tools and anything else one could stuff in there. Never gave it a thought and with a grated bottom liner all is secure. I do need a hitch box though because my power unit is 14" plus tall and I don't want to stick it out the bottom. Ease of battery removal also a factor.
I will check HF... Had no idea they had them.
I am a little confused... What is a WD hitch ?
/ Dump Trailer Tool Box #11
The bottom is expanded metal, I added a lil expanded metal section
along the top so it is impossible for anything to fall out. It is like a clam,
when the top closes it makes a box so nothing can fall out.
There is a TON of room under a dump trailer...
/ Dump Trailer Tool Box #12
Mine's a deck over so has some room under it but the piston location may be in the way, I may need to break out the welder...
/ Dump Trailer Tool Box #13
Dmace indeed, you and everyone else should capitalize on my idea.*
When I thought of it, it was an epiphany, I mean the light bulb didn't just
come on, it came on and blew up, and I instantly started making it. It
was fun to do knowing how cool it would be to stow my stuff all related
to my tractor in a protected secure area. :licking:
I am SURE others have done it but they didn't share there idea w/ this
list now did they? My way is called "Paying It Forward" and I will
continue to do so (unless I see a potential to make a buck :laughing: ) even then
I will ............... :D
Here are a few more pics. NOTE where I point. That is the upper part of
the clam shell that disallows any of my possessions to jump out when
I hit a bump. When the dump portion closes it creates a "Box" so my
stuff, remains "my" stuff!
I hope others see this and build on my idea and SHARE their builds
with others here on this list.
I also had a thought to make a spare fuel tank in there along w/ a compressed air refillable tank.
I need a spare for my trailer, anyone close got one? :)
* I mean if you are refering to my idea anyways...
I am currently in negotiations w/ a guy who has a nice Warn Winch that
I want to add to this trailer. THAT is a whole new thread when it happens
and it will be the CremDeLaCrem' I say! HA! :laughing:
I have one of those .... just didn't catch the fancy ininials description. Not a text'r ...... does it show ?
/ Dump Trailer Tool Box #17
If anybody tricks out there dump trailer undercariage post up pics here!
Lets see the work! Let the carnage begin! :D I really need to add more to mine. Right now I am rebuilding that 554 bearcat and fabricating theft
deturant devices for backflow valves x 4 all custom.
Solved the battery / hydraulic pump storage box. I built one out of 20 guage sheet metal. I could not find a prebuilt unit with the right deminsions I have that would look like it would belong. The oil reservoir and pump are 16" tall and I needed this distance to make everything fit. It turned out fine and for less than twenty dollars in material. I had enough left over to make a mid mounted mower transition to eight inch flex hose for a lawn vacuum I am building.
/ Dump Trailer Tool Box #20
Love it when a plan comes together! Good job! I started making an addition
to the under-bed storage on my trailer yesterday. This one will really holds
the goods! Pics maybe tomorrow...
2021 JCB 35Z-1 Mini Excavator (A64553)
2021 JCB 35Z-1...
2000 Club Car Turf II XRT Utility Cart (A64194)
2000 Club Car Turf...
2016 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCNKNEC1GZ163679 (A65563)
2016 Chevrolet...
2023 Tesla Model 3 Sedan (A64557)
2023 Tesla Model 3...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
86 (A63290)
86 (A63290)
