My attempt at a SSQA for Kubota
/ My attempt at a SSQA for Kubota #21
countrybumpkin,
Thanks for your reply and help with some ideas for this project.
Here is a photo of the back of my bucket.
I don't have a lot of metal working tools to bring to bear on this project. I have a local fab shop that is willing to do small odds and ends for me. I thought about a template plus some accompanying CAD drawings for clarification.
If someone knows of a reasonable kit that can be altered to work, I'd look into that as well.
Thanks
Not sure on that one right off hand, I'll have to do some research and see what I can come up with.
/ My attempt at a SSQA for Kubota #23
countrybumpkin, Great Job, exactly what I'am planning except I don't have your talent. Could you take a few more close up pictures and explain the concept of the spring pressure. The tapered pins give you a tight fit and the springs maintain. Like what size is the hole how much of the pin goes in, any help or info would be great
/ My attempt at a SSQA for Kubota #24
Well I have been wishing I had a SSQA for a long time just never could see spending the money for one, so I finally broke down and built one With scrap I had laying around and some stuff from work. I have about 100 dollars in the whole project after buying paint and a few other minor stuff.
Here are some Adapter pics
All I can say is.. Wow!
You could make some cash by have members bring their buckets to you to transform them into Q/A's.
Nice work..:thumbsup:
Thanks adiredneck.
ktm010 here is one of the threads were I found the specs for the bucket side plate. Here are a couple of pics for you if you need something else let me know. The pins engage about 90% of their full 1" width, as for the springs I have two sets on my set-up, the first set that are on the rods from the levers to the pins do two functions, one they keep pressure on the pins to keep them in place and also keeps things from rattling around. I looked at several brands of loaders and the different set-ups each had to do the same function, none seem to engage the pins the same amount, I even seen a cub cadet that the pins went completely past the tapper and the pins were loose fitting in the slots. I chose to use 1" Square pins a few brands use round. The second function of the springs keep the handles locked in the down position. The second set of springs are the black ones under the handles they keep pressure on the handles and hold them up in the unlocked position.
/ My attempt at a SSQA for Kubota #26
Very nice! :thumbsup:
One suggestion - cut the lock pins a little shorter or install some kind of skid guard for them. If you shove the pin back in (back dragging over a rock...) the force will bugger up your mechanism. Maybe with profile of your bucket this is not a issue; you could also cut the pins off shorter.
thanks mwb I have thought about the back dragging issue of hitting a pin, it is not as bad as it looks in the picks but I have been thinking of a guard for them for a just in case scenario.
/ My attempt at a SSQA for Kubota #28
Hi,
New to the board and getting ready to build a QA for my loader so that I can switch between the bucket and fork lift and hay spear.
If you would give me some more detail on your latch setup I would make drawings and post for everyone to use. Give me dimensions from latch pin to hangle/anchor bolt. Dimensions of hangle. Details details details please! Send a "napkin" sketch or whatever.
I am a design drafter by trade and would be willing to make some nice drawings.
Thanks,
Charley
/ My attempt at a SSQA for Kubota #29
subscribing
Well sense we have a couple people interested , I should give a update. Been using this now for two years and I'm not been real easy on it I have had zero problems with any of it. I have never had it come unpinned, twist , or have bent a thing. I could not be happier with this setup. And for anyone THINKING they might like one weather you build or buy one you will not be disappointed in having one. ☺☺
/ My attempt at a SSQA for Kubota #32
This post is an example of the 'beauty' of this website.
Someone is thinking about doing something similar to what has been posted, in this case, about 2 years ago, and yet, they are able to do a search and find this post to help guide them on their project or maybe even give them an idea to inspire them to do something themselves.
It's like a rural "borg" community.(Star Trek: Next Generation reference, :laughing:) The collective knowledge of all those that have posted are assimilated into a greater whole. Kind of cool really.
/ My attempt at a SSQA for Kubota #33
We are the BORG, resistance is futile. Your life as you have known it is over. You will be assimilated to serve US.
/ My attempt at a SSQA for Kubota #34
What did you use to cut the brackets off of the bucket ?
I used a torch, grinder, and cutoff wheel. Then drilled out the large spot welds in the bottom of the brackets.
/ My attempt at a SSQA for Kubota #36
Thanks! Don't have a torch, nor your skills ( fit and finish on your SSQA looks simply amazing! ), but just went over budget buying my first tractor ( Mahindra Max 28 ) and am thinking about doing something similar. Probably do something much simpler for the pins on the bottom of the QA ( e.g.: knock em in and out with a hammer and secure with a hair pin cotter ). Probably have to take it to machine shop to get the brackets cut off, and perhaps for some of the welding, all of which would certainly add a bit to the cost. Thinking that it would still probably come in considerably less than the $800 - $1000 the dealer wants for the same thing.
/ My attempt at a SSQA for Kubota #37
I don't know if this will help anyone or not, but it is good for a laugh, this link documents my trial and tribulations on converting my Kubota L3400 to SSQA.. I went ahead and bought a SSQA bucket to begin with for $600.. I did not make an adapter I just bought one for $400 and was up and going in minutes but I then decided to convert my Old bucket to SSQA, and did not think it would be a big deal.. it was more work than I figured on.. but the next one would be a lot easier, as I am a lot smarter! Like I said good for a laugh if you have the time.
http://www.tractorbynet.com/forums/customization/208653-so-you-think-converting-pin.html
James K0UA
8065 (A55852)
8065 (A55852)
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
