Hydraulic motor size
   / Hydraulic motor size #11
Save your self the money and bypass your gear box and direct drive the drill shaft. it is what I did.
Surplus Center - 28.3 cu in HYD WHEEL MOTOR W/5 BOLT HUB
Did a bit of rigging and this thing is a monster. I can post pix if you need it.
OOOooh. I like.
That's got me thinking of actually building that self powered dumper that I've had in the back of my head for a while.
I'd like to see pics of what you've done with it. I always like seeing other people's work.
Thanks!
   / Hydraulic motor size #12
jim_wilson
It takes about 34 HP at 2500 psi to run that motor hub assembly.
   / Hydraulic motor size #13
Here ya go.
All in with hoses, connectors, it was $1000. I had all the steel cut and drilled, did my own welding. Got a good bit that set me back more than I expected. And the hoses and connectors were brutal. The bit is 12" but I am sure I could spin a 30 in my dirt no problem. Just don't have the 1200 for that bit.
It eats up roots, I don't really have rocks. About the only thing that has stopped it was when I drilled into my double walled culvert by mistake. That was a mess....
For reference, I am 18GPM at 3100 PSI and a 65HP engine backing it up
   / Hydraulic motor size #14
jim_wilson
I'm going to have to bone up more on my hydraulics knowledge to get a better understanding of all of this. What kind of hydraulic pump would it take to drive four of those motor hub assemblies?
   / Hydraulic motor size #15
If you used 4 of those motor, then you would have to pump about 80 GPM, and at 3000 psi, HP required would be about 164.
Try some smaller wheel motors.
Surplus Center
   / Hydraulic motor size #16
Surplus Center
I'm probably approaching this from the wrong angle.
Is there a formula for how much torque from a wheel motor it would take to move a certain amount of weight at a certain speed?
For instance if I had four driven wheels - and I wanted to move 10,000 pounds at 5mph - how would I figure the wheel motor requirements to do that?
   / Hydraulic motor size #17
That kind of engineering is a little bit above my level
For that much weight, I would compare the hyd motors on a large skidsteer, or something equivalent.
That is alot simpler way to get to where I want to go. Did you just build an adapter for the auger and bolt it onto the motor or is there more to that connection than I see?
I was shopping for flush face hydraulic adapters and noticed that the 1/2 inch only seems to flow 11gpm. That is about half what I can produce. Am I onto the wrong thing or is 11gpm all a half inch connector will flow?
Jim what kind of connectors do you have on your setup?
JJ any advice? it appears that that motor Jim posted has 1/2 in bsppm but indicates that it has a 20-24 gpm flow rating. That leads me to believe that a 1/2 inch port must have the capability to flow at least 20-24 gpm?
School me fellas!!
   / Hydraulic motor size #20
Are you referring to my build Rio?
I kept the wheel motor hub, basically I plan to put a log splitter on it later...
I then had a round peice of steel cut, appropriate holes drilled, and a pole welded to it. Bolted it on. Now I can take any 2" round auger bits.
Carl
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2011 Ford Edge (A53424)
2011 Ford Edge...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2015 Chevrolet...
