orchard ladder
   / orchard ladder #1
randy41
Linden VA
the 'dwarf' cherry trees we have are loaded with fruit this year. this is probably a result of the mild winter. i don't own an orchard ladder. the dwarf trees are at least 20' tall. not very dwarfy. any thoughts on how to convert a regular aluminum extension ladder to an orchard ladder?
   / orchard ladder #2
When I saw your thread, I realized I had never seen the term "orchard ladder" before so I did a Google search. It seems to me that any conversion of a standard extension ladder to an orchard ladder would be quite unsafe as it would lack the widespread base of an orchard ladder. It may be safer and more practical to convert a heavy duty stepladder but I don't know where one would obtain the third leg required. Wish I could be more helpful. I use a heavy duty 10' stepladder to harvest peaches and moving that thing around is a huge PIB.
   / orchard ladder #3
Had a buddy make one out of 3 2x4s for legs then add 2x4 rungs on one side. Length of chain attached from back support to each side of the leg. May be an option.
   / orchard ladder #4
Op asked about converting his extension ladder and I didn't even think about making one from scratch. Even if built with SYP lumber I would be very uncomfortable climbing anything made out of 2X4's higher than 5-7 feet. I do like the idea of using chain for the back support. Perhaps use a bolted-thru gate hinge to fasten the third leg at the top? However, need to devise a method so the third leg cannot fold up at the wrong time...
   / orchard ladder #5
20 feet high reaching for cherries.. no way unless you rent a bucket truck:)
A good producing cherry tree should have plenty of clusters nearer to the ground. I'd pick what is safe to reach... you be the judge of your own safety... and let the birds have the rest.
Do you prune the trees every year? The reason I ask is why did it get that tall in the first place?
There are 2-3 ranges of "dwarf" but non are meant to allow to grow that tall
for picking fruit.
If you really have to have the fruit from the high branches this year you might suspend netting off the ground and cut the branches with a long pruning pole after you have picked the low branches. You might save a few from the high branches that way or just make juice from them.
The pruning would put you ahead for next year if you don't kill the tree.
How do you spray effectivley in a 20 foot high fruit tree?
Is it a self pollenator or do you have another near by?
Good Luck:D
   / orchard ladder #6
You could probably modify an extension ladder to make it like this one:
Orchard Ladder
But why risk your safety? Just buy an orchard ladder, or something like this that will fit cherries.
Pole Fruit Picker
Bruce
   / orchard ladder
for picking fruit.
Good Luck:D
i don't do anything to these trees. they have some kind of tree disease and lose their foliage way before fall. so are you saying i have to prune the trees to make them stay dwarfs? i thought that would be in their breeding.
i've had these trees for at least 15 years and this would be the second crop i can harvest more than just a few. i don't spray.
   / orchard ladder #8
Cherry trees are very particular. The leaves fall off early when the summer is too dry, but they don't like too much water either. They prefer a certain type of soil to produce well. An area above Chicago produces most of the commercial cherries, or so I have been told. We live in OH and have a couple cherry trees that don't do much either most years. We even grafted another type cherry to them but it didn't improve anything. We just enjoy the blooms
and the birds enjoy the cherries.
On the other hand we have apples and pears that do very well in the same soil.
   / orchard ladder #9
Pole Fruit Picker
Be careful with something like that as it might get you the fruit but you don't want to break off the woody spur as that will be next years fruiting wood. That is why they generally say to keep the stem along with the cherries as it means you have to pick them individually versus grabbing a whole hand full which usually brings the woody spur as well.
Stems are also a good indicator of how old the cherries are. When buying cherries you want to look for green stems. If they are brown and old looking the cherries have been sitting around a while.
Around here orchard ladders come up on the Craigslist once in a while, just something you have to keep you eyes open for.
   / orchard ladder #10
If you were coming through this area I would sell you one of my extra orchard ladders. I have 10-12 of the 8' orchard ladders and really only use a few of them. We bought them when a pick your own operation went out of business. Only wanted a couple but bought the whole lot thinking my orchard would be profitable but that never materialized (walmart and the older generation passing away has really killed the road side stand market that my neighbor raised his entire family off of).
(APPROX. 20) 4' X...
2002 Ford E-450 Enclosed Service Van (A59230)
2002 Ford E-450...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
New Holland 3930 (A60462)
New Holland 3930...
Pintle Hitch Triple Axle Trailer - NO TITLE (A59814)
Pintle Hitch...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
