Weight of 48 Backhoe
   / Weight of 48 Backhoe #1
MMH
Gold Member
Murrysville, PA
JD 4500
What is the weight of a 48 Backhoe (backhoe for a 4500 tractor)? THe operators manual lists 670 lbs. I would have thought that this backhoe would be much heavier.
   / Weight of 48 Backhoe #2
MMH
According to Post#5 on thread "John Deere Backhoe Model Confusion" on this site, the poster mentions JD got the lbs/kg weights switched...should be 1477lbs (671kg) for the Model 48 w/ Medium Frame Adapter and 1517lbs (690kg) for the Large Frame Adapter. Not sure if those weights include a bucket or not though...unless stated otherwise, I assume not.
MMH
You are correct - JD reversed the numbers for Kg. & lbs. W/ or w/o bucket, the 1517 lbs. makes allot more sense. BTW, I could not locate the link that you you referenced.
   / Weight of 48 Backhoe #4
Here's a *.pdf file I downloaded a few years ago. Hopefully, I can attach it..
AKfish
  • JD447-448 BackHoe OM 08 Specifications.pdf
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
2023 G Bar K Skirted Hauler Bed (A55218)
2023 G Bar K...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55218)
Kubota BX2680...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
