Weight of 48 Backhoe
   / Weight of 48 Backhoe #1
MMH
Murrysville, PA
JD 4500
What is the weight of a 48 Backhoe (backhoe for a 4500 tractor)? THe operators manual lists 670 lbs. I would have thought that this backhoe would be much heavier.
   / Weight of 48 Backhoe #2
MMH
According to Post#5 on thread "John Deere Backhoe Model Confusion" on this site, the poster mentions JD got the lbs/kg weights switched...should be 1477lbs (671kg) for the Model 48 w/ Medium Frame Adapter and 1517lbs (690kg) for the Large Frame Adapter. Not sure if those weights include a bucket or not though...unless stated otherwise, I assume not.
MMH
You are correct - JD reversed the numbers for Kg. & lbs. W/ or w/o bucket, the 1517 lbs. makes allot more sense. BTW, I could not locate the link that you you referenced.
   / Weight of 48 Backhoe #4
Here's a *.pdf file I downloaded a few years ago. Hopefully, I can attach it..
AKfish
  • JD447-448 BackHoe OM 08 Specifications.pdf
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2022 BMW X7 xDrive40i AWD SUV (A53424)
2022 BMW X7...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
