Weight of 48 Backhoe
   / Weight of 48 Backhoe #1
MMH
Murrysville, PA
JD 4500
What is the weight of a 48 Backhoe (backhoe for a 4500 tractor)? THe operators manual lists 670 lbs. I would have thought that this backhoe would be much heavier.
   / Weight of 48 Backhoe #2
MMH
According to Post#5 on thread "John Deere Backhoe Model Confusion" on this site, the poster mentions JD got the lbs/kg weights switched...should be 1477lbs (671kg) for the Model 48 w/ Medium Frame Adapter and 1517lbs (690kg) for the Large Frame Adapter. Not sure if those weights include a bucket or not though...unless stated otherwise, I assume not.
MMH
You are correct - JD reversed the numbers for Kg. & lbs. W/ or w/o bucket, the 1517 lbs. makes allot more sense. BTW, I could not locate the link that you you referenced.
   / Weight of 48 Backhoe #4
Here's a *.pdf file I downloaded a few years ago. Hopefully, I can attach it..
AKfish
  • JD447-448 BackHoe OM 08 Specifications.pdf
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
JCB 2145 (A47477)
JCB 2145 (A47477)
