fill tires or not?
   / fill tires or not? #51
Rimguard seems to be a very reasonable price
I thought so too, especially after I realized how expensive the John Deere wheel weights were.
//greg//
   / fill tires or not? #52
Another thing about wheel weights brought to my attention by a neighbor with a Kubota. Wheel weights are great at holding dirt and moisture close to the rim out of sight. Add in a little road salt from your road crew and they can rot out your rims from the outside faster then calcium chloride will from the inside.
   / fill tires or not? #53
"Another thing about wheel weights brought to my attention by a neighbor with a Kubota. Wheel weights are great at holding dirt and moisture close to the rim out of sight. Add in a little road salt from your road crew and they can rot out your rims from the outside faster then calcium chloride will from the inside."
Can anyone speak to whether or not this is true????
   / fill tires or not? #54
The way I interpret vtsnowedin's comment is that his neighbor *showed* him the condition of his rims as a result of using weights, and I would expect that would be the sort of commentary you're asking for.
   / fill tires or not? #55
Though I haven't experienced it, I can certainly see how that could happen. I have seen that sort of thing happen with CaCl on snow plows. It's awful.
   / fill tires or not? #56
sorry to bother you guys with another question but... everyone on here says to fill the back tires for ballast and stablition. so i called the dealer and was going to have him fill my tires before i picked up my 3032 next week. he says deere doesn't recommend filling them because of the damage to the rims. will this scew up my warranty if i fill them somwhere else?
My brand new 4720 has ballast info in owners manual....Imm adding 55 gal per tire this week. Calcium Chloride is the issue...and anyone with a brain will have tubes in those tires so the fluid will not contact thee rims anyway
   / fill tires or not? #57
55 gallons of... ? And, how much additional weight will that add for you? Why 55 gallons? And, does that bring it above the rim on top (leaving some space for air above?
Just trying to follow how you got to that amount...
One of the things I remember about loading tires when I was deciding whether to or not (and what to use) is that you need to fill to a point where the fluid is above the rim. This ensures that the rims are [almost] never exposed to the air inside the tires and should drastically reduce any sort of corrosion that might occur.
+1 on the idea of filling with CaCl only if your tires have tubes. *However*... Add in the cost of removing the rim from the tractor, possible transport to a tire shop / dealer, unmounting the tire, purchasing the tube, installing the tube, and remounting the tire to the total cost. Once you've added all of that in, it will probably have a much higher actual cost than having someone drive out to you and fill with Rimguard (or something else).
   / fill tires or not? #58
Actually the neighbor was explaining why he had not bought any wheel weights for his current tractor based on his prior experience. Seeing how sand and salt gets into every crevice of state snow removal equipment and the amount of rust it causes I have to think he has a valid point. Taking the weights off each spring and cleaning and perhaps never seize the contact surfaces should remove any doubt.
   / fill tires or not? #59
Water/Methanol mix..
55 gal is what the chart says I need.
Im fortunate I guess that my tire guy is very reasonable on price. I would love rim guard but the closest dealer is to far for me to bother with it
In this area we all use tubes in tractors used in the timber and around our many thorn bushes and trees
   / fill tires or not? #60
Ah... No visual, but was experience-based.
Personally, I don't like the idea of weights because it places additional weight directly on the rims / axle, and they protrude beyond the sides of the tires (increasing total width). Loading the tires puts the weight directly where it's needed - on top of the contact patch of the tire.
(INOP) KUBOTA RTV900 UTV (A57192)
(INOP) KUBOTA...
2022 Dodge Ram 4500 Miller 8,000lbs Wrecker Tow Truck (A55852)
2022 Dodge Ram...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2017 CATERPILLAR M316F MOBILE EXCAVATOR (A52707)
2017 CATERPILLAR...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56435)
2019 BOBCAT T630...
