I'm pretty late to the party, but I got a few laughs out of this.
Just to clarify something, or at least try. On a pressure vessel (MBH is the prefix for naming that according to the API) it is completely legal to weld. We had one with a corroded spot that finally went all the way through. The procedure, written and approved by a govt. agency) was to fill the pit with 6010 rods flush to the origanil vessel, then cap wth 7018. After that it was UT inspected.
I'm sure this will just start another arguement but oh well. There is no way I will put the procedure on here for fear it may be considered proprietary or something by my company. I would like to continue my employment here.
If it makes you feel any better the one we welded contains natural gas and crude oil at about 600psi. It is about 30' long and 8' diameter, so there is probably more volume than your air tank I assume. Oh, and my bed is about 40 feet away from it and I sleep pretty good at night.
I work in the middle of the Gulf of Mexico and the salt eats everything up pretty quick. It is fairly common to make this sort of repair.
I am not sure it could have been 6011 or 6013 I am not sure at this point. I know it wasn't 7018, because all I had at that time was an AC welder so it was one of those two rods.. James K0UA
i know a ford owner would weld it up and keep working..![]()
On my air compressor, it developed a leak at the bottom about 6 years ago at the junction of the original weld. The original weld was a poor weld, instead of a nice clean start and go around the endcap, and stop in line at the end, and tie in, they missed the tie in and went past the original bead line but a left a gap between the two. I rewelded it, I am not sure it could have been 6011 or 6013 I am not sure at this point. I know it wasn't 7018, because all I had at that time was an AC welder so it was one of those two rods.. It has held fine since then. The max pressure in the tank is 130 lbs. OK, Am I at serious risk of death and destruction? The way I figured it I did a better weld than the original guy did. Let's hear what you think.
James K0UA
