Method of bush hogging
   / Method of bush hogging #1
remington270
Alabama
Kubota M7040, Kubota B2710
What is your preferred method in wasting as little time as possible in cutting a field that's roughly rectangular? Spiraling around the edge going inward, long straight parallel paths, etc. My pet peeve is backing up, or riding and not cutting.
   / Method of bush hogging #2
I like to start spiraling until I have a turn row on short side,then just turn back onto last swath.
   / Method of bush hogging #3
X2
E/S
   / Method of bush hogging #4
I start on the outside and work toward the inside. Due to the geometry of a rectangle and the turning radius of a tractor I think it's impossible to mow without wasting some time remowing the ends (width).
   / Method of bush hogging #6
I curve my corners as soon as possible so that, as I make my turns, the cutter is still doing its work on the tall grass. This means doing some backing-and-forthing in the initial passes, but it's more efficient over the long haul in my opinion.
I've also learned that the direction of travel makes a huge difference in the quality of the cut, even on corners. The blades of my cutter travel counterclockwise, so that's my direction of travel. Going the other direction leaves many, long strips of uncut grass.
   / Method of bush hogging #8
Two or three laps around the outside. Then cut parallel about 8-10 cut widths over from the longest edge, turn and return down the long edge. Keep this "circle" going untill everything is mowed between your first cut thru the field and the edge. Make another parallel cut 8-10 cut widths over. Continue until complete.
   / Method of bush hogging #9
This too is my method but I each time I mow, I change the pattern 90 degrees to be sure to get any remnant of higher weeds left over from the time before.
   / Method of bush hogging #10
I do the same :thumbsup:, unless it's a real long narrow parcel, then I try and run 1/2 a width over from the last time I mowed.
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2013 Nissan Rogue S SUV (A50324)
2013 Nissan Rogue...
43014 (A51691)
43014 (A51691)
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
