Light Duty Pallet Forks for 2305
   / Light Duty Pallet Forks for 2305 #11
I bought a light duty set (800lb) on E-bay about a year ago.
TWO items....they promptly BENT when lifting a water tank of 100 gallons....approx (800 lb.)
I E-mailed the seller and he generously replaced them with HEAVY duty forks.
They are MUCH heavier guage steel with deeper attachment "arms" and heavier lugs to cinch them down.
But.....they are HEAVIER.....much heavier, I'm guessing 70 lbs per fork. That's heavy for a fellow to install/remove often.
About the bucket.....after lifting water tanks 8+ times my bucket is showing a definate droop or bend in the center. Suggestion might be less weight.....perhaps a 2X4 from fork to fork where they clamp to the bucket or even a steel plate welded in the attachment area.
One other item;......lift capability. My compact Kubota has a 1,000lb limit. The bucket probably weighs 300lbs. leaving 700 as an actual load. If you add 150 lb for forks you are greatly reducing the lift capability. I learned this trying to lift that 100 gallon water tank.
look on E-bay and Good luck
   / Light Duty Pallet Forks for 2305 #12
We offer an excellent set of compact pallet forks built with the JOHN DEERE Hookup to fit the CX 200, 300, 400 SERIES and H120 JD FRONT END LOADERS with special JD quick attach. They are lightweight(220 pounds) and are rated to 1,800 pounds so they're good on most compact tractors up to around 50hp. These are generally preferred over the type that clamp on the bucket because of the risk of bending your bucket with the clamp on style.
Check them out here.
   / Light Duty Pallet Forks for 2305 #15
Check the dates....this is a six year old thread.:laughing::laughing:
But, the best forks for small JD's are from Artillian Tractor Attachments
Your right X2 Kenny! Why this thread got revived, I don't know. The best forks for that size tractor are Artillian :thumbsup:
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2013 Ford Escape (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
2016 Freightliner 114SD Tandem Axle Dump Truck, VIN # 1FVHG3DV7GHGW6796 (A51572)
2016 Freightliner...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
