Ballast Box that Attaches to Box Blade?
   / Ballast Box that Attaches to Box Blade? #1
robertwhite
Does anyone have a ballast box that attaches easily to a box blade? Homemade or store bought, pictures please.
My 6ft box blade weighs 600lbs (???) and I sure would like more counterweight when using the seriously large (deep) 78" loader that comes with my Mahindra 6530.
   / Ballast Box that Attaches to Box Blade? #2
My box blade is 5 feet wide, I bolted on 2 pieces of one inch steel plate, 10 x 22 just over 60 pounds each.
I should have mentioned that I would like to use suicase weights with the add on box.
   / Ballast Box that Attaches to Box Blade? #4
When I need additional weight for counter balance I add six 42 lb suitcase weights.
   / Ballast Box that Attaches to Box Blade? #6
Robert what I am thinking is you need another 600 lbs in weights.. So maybe a large square box on top of the box blade you can fill with at least a dozen or more of those weights. Check your manual or loader manual and it will have a suggested ballast for your 3pt. But I am betting 1200 or more is about right for that size tractor. Or make a dedicated ballast box, from scratch.
James K0UA
   / Ballast Box that Attaches to Box Blade? #8
I made a cradle that holds a 55 gallon plastic drum sideways out of 2X6 pressure treated lumber. The water weight is about 450 pounds (water is about 8.3 lbs a gallon I think) and the cradle is about 40 pounds. I would think you could get two on your box blade. It is a fairly inexpensive possibility.
Thats what I figure too. But the problem is that short of welding up my own carry nox, I dont know of anything else to use.
Nope, wont work for my needs. If I need to take the weight off, I would have to drain all that water. Need something that will be easily weighted and unweighted.
2019 Komatsu PC490LC-11 Hydraulic Excavator (A49461)
2019 Komatsu...
2014 Gleaner 3000-R8 Corn Head (A50657)
2014 Gleaner...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2017 Miller Nitro 6300 Self Propelled Sprayer (A50657)
2017 Miller Nitro...
2014 MACK GU (GRANITE) (A50854)
2014 MACK GU...
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
