Ballast Box that Attaches to Box Blade?
   / Ballast Box that Attaches to Box Blade? #1
robertwhite
Does anyone have a ballast box that attaches easily to a box blade? Homemade or store bought, pictures please.
My 6ft box blade weighs 600lbs (???) and I sure would like more counterweight when using the seriously large (deep) 78" loader that comes with my Mahindra 6530.
   / Ballast Box that Attaches to Box Blade? #2
My box blade is 5 feet wide, I bolted on 2 pieces of one inch steel plate, 10 x 22 just over 60 pounds each.
I should have mentioned that I would like to use suicase weights with the add on box.
   / Ballast Box that Attaches to Box Blade? #4
When I need additional weight for counter balance I add six 42 lb suitcase weights.
   / Ballast Box that Attaches to Box Blade? #6
Robert what I am thinking is you need another 600 lbs in weights.. So maybe a large square box on top of the box blade you can fill with at least a dozen or more of those weights. Check your manual or loader manual and it will have a suggested ballast for your 3pt. But I am betting 1200 or more is about right for that size tractor. Or make a dedicated ballast box, from scratch.
James K0UA
   / Ballast Box that Attaches to Box Blade? #8
I made a cradle that holds a 55 gallon plastic drum sideways out of 2X6 pressure treated lumber. The water weight is about 450 pounds (water is about 8.3 lbs a gallon I think) and the cradle is about 40 pounds. I would think you could get two on your box blade. It is a fairly inexpensive possibility.
Thats what I figure too. But the problem is that short of welding up my own carry nox, I dont know of anything else to use.
Nope, wont work for my needs. If I need to take the weight off, I would have to drain all that water. Need something that will be easily weighted and unweighted.
19015 (A53422)
19015 (A53422)
Hose Reel (A55758)
Hose Reel (A55758)
2023 Chevrolet Tahoe SUV (A55853)
2023 Chevrolet...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
CATERPILLAR 259D3 SKID STEER (A52707)
CATERPILLAR 259D3...
2003 Chevrolet 1500 Silverado Crew Cab Pick-up Truck (A55852)
2003 Chevrolet...
