Finish mower or zero turn
   / Finish mower or zero turn #11
I went from a rotary cutter to a finish mower and was amazed at how much nicer the finish was. Then I went to a zero turn mower and was amazed at how much nicer the grass looks compared to the finish mower. Unfortunately, I now like the results that I get from the zero turn so much better that I've more then doubled the amount of grass that I maintain with it!!!!
Be careful, be VERY CAREFUL!!! :laughing:
Eddie
   / Finish mower or zero turn #12
I was enthused at the purchase of a $5600 ZTR, but got my money back the very next day. It was incapable of holding on a hill, nor could it reverse uphill. If you're a flat-lander, go for it. But if you've got hillsides - or even meaningful rises in your lawn - you'll be disappointed.
//greg//
   / Finish mower or zero turn #13
I have mowed with both a tractor with a 3 pt finish mower, and a ZTR. The ZTR is easier, quicker and gives a better quality cut.
   / Finish mower or zero turn #14
Everybody here seems to be missing the most important point. The ZTR is WAY more fun to mow with!!! I agree with everything else said too.
   / Finish mower or zero turn #15
//greg//
I haven't had any of these problems with my ZTR, but I don't mow hillsides. One TBN's advertisers, Ted Corriher at (http://www.everythingattachments.com/default.asp), has invented a front-braking system for ZTRs: Zero Turn Mower Front Brakes!! Check it out [url]www.tedbrakes.com - YouTube[/URL]. Here's wishing him success.
Steve
   / Finish mower or zero turn #16
//greg//
I can mow the side banks of my ditches without much problem, I use a Ferris IS3000. They are as steep as you would ever want to go, in fact with the JD lawn tractor I used previously, I had to go straight up and down. If the grass is wet, forget it.
   / Finish mower or zero turn #17
I like using a 3PH RFM. With the 5 footer it took me a little over 1/2 hour per acre, and although I haven't timed mowing since getting the 6 footer I suspect it is less. Time on the tractor is therapy for me, not a race.
   / Finish mower or zero turn #18
Until five years ago I would have said, just use the RFM. I'm always trying to save a buck. Now that I'm living in a place with more grass I will definitely recommend a zero turn. I enjoy mowing with a tractor or a zero turn and do both still. But at the house the grass needs to be mowed regardless of wether you have time or not. I found that with my schedule there wasn't enough daylight, especially at the end of the growing season, to get it done without a fast mower. Replaced my Case 254 with a woods RM59 with a Exmark Lazer Z with a 48 inch deck then "upgraded" to a 61 inch Woods diesel mower. Every step has reduced my time needed. And has allowed me to get the look I want with less time invested.
Chuck
Thank's for all your opinions and advice, it seems pretty much unanimous that the zero turn mower is the way to go, I have been looking at a Gravely ZT XL 54"cut, do any of you know anything about the Gravely's or have an opinion on another zero turn that I should consider?
   / Finish mower or zero turn #20
I think Scag and Kubota diesels are thought of as being top notch. My husqvarna is gas and does great.
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Landhonor HD Wheel Balancer (A59814)
Landhonor HD Wheel...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
2018 KOMATSU PC88MR-10 EXCAVATOR (A60429)
2018 KOMATSU...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
