Post frame building slab.....
/ Post frame building slab..... #1
Kenfyoozed
Mobile, Al
1974 MF135
I am building a post frame metal building.30'x40' with a 10' leanto off the back. This will make the slab part 40'x40'. I have only had one estimate and waiting to get more. But not sure what to look for or what i need. I live in South Alabama. The concrete guy said 4" thick slab with 6" footers, using fiber mesh and no rebar. I will use this as a work shop and to house my "toys" ie; lawn mower, tractor, 4 wheelers etc....
Would you guys mind pointing me in the right direction?
Thanks in advance.
/ Post frame building slab..... #2
That is what I did on my barn (4", fiber, no wire, footers). I have not had any cracks from tractors, trucks, loaded trailers or anything else. The only crack that happenned was in the tack room with nothing heavier than me going in there. I guess it must have settled there or somehting.
/ Post frame building slab..... #3
I have had 2 30x40 pole barns built 1 w/fiber no footings 1 w/rebar no footings and a 20x20 garage w/wire and footings. They all cracked but using stress cuts or what ever they are called help to control that some what. The only thing with the fiber and not sure if it was not finished right but the fibers came to the surface in some spots? Seems like all concrete cracks some time or other in its life or I just was not lucky enough to get it done right? Oh and all were in the 4" range of thickness. Good luck.
/ Post frame building slab..... #4
I graded formed and had a 40' X 65' slab poured. I got the "With fiber you don't need rebar" sales pitch.
WELL obviously they never go back and look at the slab 11 years later!
I've got areas that have heaved up or dropped an inch and cracks! And these are areas that I scraped down to level, no fill what so ever!
I think fiber is BS just so the concrete co can get $4. more a yard and the drop and finish crew doesn't have to work around rebar or wire! With rebar and or mesh there is no guessing if will it crack and lift later.
Talked with the concrete guy again. He does use wire mesh. So will thise be adequate? And the footers are 8 inches deep.
/ Post frame building slab..... #6
Where I live (Central TX), every reputable concrete guy will say you need wire mesh, rebar, grade beams and you can add the fiber if you want to avoid hireline cracks.
Now, I also live on the Blackland Prarrie and the soild has a very high plasticity rating--it moves a loT. During the high summer, we have crack open up that you cannot see the bottom of.
/ Post frame building slab..... #7
The ground beneath the slab must be adequately compacted. If it's undisturbed soil, running a heavy piece of machinery back and forth over the area should do it. Just don't tear it up.
3" of clean, washed 3/4" gravel should be next, followed by a layer of 6 mil. poly sheeting.
Mesh is good, don't omit it no matter what concrete you use. Be sure the mesh is supported on wire or brick "chairs", to keep it suspended in the concrete. It does no good down at the bottom.
Wet concrete is weak concrete. Be sure that the compressive strength is what you want (3,500lb?) and that they don't add water to make it easier to spread. You would need special tools to check the slump; the concrete should appear fairly stiff and not at all soupy. Plenty of aggregate (gravel) is good.
Be sure that they provide relief cuts every 10 feet. This will help reduce cracking.
Several hours after the pour, cover the slab with 6 mil. poly. Staring the following day, each morning lift the plastic and sprinkle lightly with water. Keep covered for 3 days.
Use a good sealer, and you're done.
Best of luck!
/ Post frame building slab..... #8
I live North of you in Alabama, I had a 30x50 slab poured in a pole barn. The fella that poured mine didn't recommend fiber his response was,"we all thought it was a great idea, but since I've been using it I've decided that it doesn't replace the wire or rebar". My floor has mesh and rebar. I think the rebar was only on 24" center. In the doorway where I pull my tractor and other equipment in, the slab is a full 6" thick 10ft wide and about 24ft long, was very easy to reinforce that area prior to the pour. During the pour, Steve(contracted with crew to pour and finish) said that "it's probably the strongest floor in the county". My advise is to make sure it's a little overbuilt because it would be a sad sick day to have it done and then a crack across the floor. I have crack control joints sawcut and thus far after about 5 years no visible cracks.
/ Post frame building slab..... #9
I plan to build a 36x48 shop (studded walls) on a floating slab with heated floor here in Wisconsin. That's not a problem. Now, we decided we would like a 12ft open canopy/lean-to on one side. If the canopy is pole type construction(poles down four ft. below frost level) and the slab is always heated, will this work? What if the slab is not heated for a season? Will the slab shift and pole part not? Is there a better way to add the canopy?
/ Post frame building slab..... #10
most ever awning on a pole barn or steel building, is done much the same way,
one could always pour a concrete column in the earth, and bolt a pipe/tube on it to support the awning
If your planning on heating the floor one should put a thermo break (insulation board) between the floor and the out side any way,
and many around here use a trencher to make a "stem wall" when pouring a slab like that, kinda of a cross between a stem wall footer system and a floating slab,
in our country very little water will come up from under the building, thus there is nothing to freeze in the soil to make it expand, if you go under a building it is very dry and dusty, and or if you up a slab if there is a edge at all, it is dry,
some also depends on your soils, if there expansive, and if they are it could be good to dig down and remove and bring in some type of fill that is not expansive,
the fiber mesh does not replace wire or rebar, but IMO makes a better floor, and when welding or cutting less popping of the slab occurs,
you still need to run your rebar, (never was big believer in the wire) besides making it much harder take up a slab if it needs replaced, out side I think wire if placed correctly is good, but one gets it placed properly so seldom, most of the time it is on the bottom of the slab 1/2 in the grade and just on he bottom of the concrete most of the time.
If your jack hammering concrete out, the fiber offers very little restance to the process of breaking up the slab,
I would pour 6" in the drive way areas at least, on the edges where the benches and storage is 4 is fine,
I would ring the slab with rebar,1/2" at lest one if not two, and lap the ends, if some thing does crack it will not move away, as easily.
concrete by it nature will basically crack about ever 10-12 foot so cut joints or grove it to have straight cracks. try to not have cold joints where there is a large time lag between trucks and the concrete starts to set before the other truck gets there, if a know time is a have to one could be wise to set a tempory form board and make it nice and straight and when the other truck gets there pull it and continue at least the break will be straight if it does break at the meeting of the two loads
if possible try not to have sharp in side corners like around a pillar or footer, if you have to have a control joint in line with the footer/pillar.
my two cents
/ Post frame building slab..... #11
if you have had that much problem your base and preparation was faulty.
if the soil moves under the slab it is going to break the concrete up,
I have seen 75 year old slabs with out any steel mesh or wire, of any type nearly (and hand mixed to boot), with out any major problems and I have seen new that is a disaster in just months, (it like road) if the base is not done properly the top is not going to last long,
and a proper base is not nessarly no fill, but building up the proper bed with the correct soils, (sounds like you have expansive soils or a lot of organic in your soils or both).
all top soils should be removed, and a base built up of non expansive soils and properly compacted,
I worked in Wyoming for a time and in this one location, and there they would dig down 4 or 5 foot, and start with placing up to 12" rocks and then other smaller and then gravel type fill, and properly compacting it as they went and then in theory they would not lift and shift, and even then it was not fool proof. very expansive soils.
saw another thing done from a builder that had worked in expansive soils.
when they did basement frame walls they would cut the frame wall about 3 inches short. and then add a 2x4 to the floor leaving about the distance of tall trim, then they would drive nails between the "Bottom" plate and the plate that was on the slab and the space was so the floor could float up and down and not push the house up an down, the trim was to attach on the bottom plate and the dry wall stop at the bottom of the wall plate, so there the idea was let it float,
one way to have less problem is more small slabs they may not stay even to each other tho, a series of 10 x 10 foot pours,
/ Post frame building slab..... #12
Most problems with slabs on grade are the result of poor construction methods and practices. Most contractors that due primarily residential work are the least informed as to all the proper methods and procedures. Quite often 3-4 different sub contractors and/or tradesmen are involved. Success starts at how the total site preparation is done. Un-compacted filled areas are a disaster in the making if that is where the slab is going to be, worse is slabs spanning both unfilled and filled areas. Reinforcing of either type is useless if it is walked on by the spreading methods. Adding water at the site to the truck so it is easy to spread will give poor results in strength and shrinkage cracks and can effect the surface appearance. Yes concrete cracks but you have to tell it to crack where you want it. Control joints cut the next day after placement are a waste of time and money as the concrete has already cracked where it wants. I have done large 4" fiber concrete slabs with no mesh or rebar and 20 years later, no cracks and have even run concrete trucks over it. I didn't do my garage and driveway but after 15 years there are no cracks anywhere.
This whole subject is two complex and technical for a forum like this. There are many many variables that need to be considered and it starts with coordination by the prime contractor to keep all the players following the play book.
The American Concrete Institute are the experts and publish all the standards, procedures, and methodology. The building codes reference their standards. Large commercial/industrial/government projects require various levels of ACI certified testers, inspectors, supervisors, and finishers to assure the project specifications and the codes are complied with by all players. Small projects don't warrant that level of effort or cost but the principles are the same. Otherwise you get what you pay for.
Ron
Ron
UNUSED FUTURE ELECTRIC WET POLISHER (A60430)
UNUSED FUTURE...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
23105 (A56859)
23105 (A56859)
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
UNUSED FUTURE MINI EXCAVATOR WOOD GRAPPLE (A60432)
UNUSED FUTURE MINI...
SCAN TO RECEIVE TEXT UPDATES (A60429)
SCAN TO RECEIVE...
