Man Killed Pulling a Log
   / Man Killed Pulling a Log #1
fishmen222
Member
Carson, VA
John Deere 755
A man was killed yesterday in Henrico County here in Virginia while attempting to pull a fallen tree when the chain snapped. You do not hear of this often, but it does happen. I learned many years ago when winching folks out of the sand while surf fishing to always dampen the chain/cable with something handy. I always used two floor mats from the truck. In the woods here, I use a spare choker chain (key aspect-not under tension) laying on the pulling chain. It does not have to be something super heavy, just enough to break up the stored energy. People under estimate the energy stored when pulling something heavy. If it breaks free, it can injure or kill you. Cables and nylon straps that stretch more are the worst. Most of you probably knew this, but just thought I would post.
   / Man Killed Pulling a Log #2
Would be a great thread start, over in the 'safety' forum. A link to the news report would be helpful also(if available)
   / Man Killed Pulling a Log #3
That was an extremely unfortunate event, for sure.
I agree that putting these things under tension has its dangers. Can you elaborate more on the method to "dampen" cables, wires, chains, and the like? I would love to know more about how to be more safe while I'm working with machinery.
   / Man Killed Pulling a Log #4
I use those cheap blue tarps, hang over cable or chain. And do not use a chain or cable to jerk, a load or stuck vehical, because something will break!:eek: Thats what large tow straps are for.
   / Man Killed Pulling a Log #5
Thank you for this very wise reminder.
I'm not a big fan of towing other people's vehichles, cause then the breakage becomes my fault. Skidding trees with a tractor DOES put me right in the crosshairs of a rouge cable/chain. Maybe the wife will buy a winch with my life insurance proceeds:confused3:
For un-sticking vehichles, many people put an old tire between the two chain halves. This prolly won't mitigate the flying chain synrome much, but tends to absorb some of the 'jerk'.
   / Man Killed Pulling a Log #6
Thank you for the reminder and the tip. Very good to know.
   / Man Killed Pulling a Log #8
I'm not sure if putting an object on the tensioned line really works. I once saw a story about a Rescue Squad who did a test by putting their fire coat on the winch cable. I think in the end it had very little affect...
That aside, that's what we still do at my Fire Department:
Is a tarp enough weight???
In no way do I claim to be a physisist, but it is my understanding that you want to interupt the initial kenetic energy stored in the pulling device. The end where it breaks releases the most energy as it has the least mass to move initially. When it reaches something that is static, that item helps disipate the energy. It is not a cure all but in my novice experience, it helps a lot. I cannot speak to the tarp, but floor mats have worked at the beach on 1/4 and 3/8" cable. I have not had a chain break, but I still use a dampner on them. You would obviously want to research further with professional facts versus my personal experience. Just wanted folks to be aware of this possibility.
   / Man Killed Pulling a Log #10
Based upon what I've read I'm leaning toward use of a recovery strap - a strap which stretches to some extent and has NO hardware. The connections are all done via sewn loops - no metal of any kind.
See Recovery Straps - Tow Straps - Proper Usage
I like that idea (I've seen it elsewhere) to put something (a length of carpeting, a tarp, several jackets?) over the strap maybe 2/3's of the way toward the thing being pulled.
   / Man Killed Pulling a Log #11
Thanks for the reminder. I try and be carefully when I pull out my logs with chains. Usually I have been able to get right up to the log which keeps the chain very short. :)
   / Man Killed Pulling a Log #12
View attachment 272179Is a tarp enough weight???
Take or 4 or 5 feet of large hyd hose nylon sheathing and fill it with small river washed pebbles and knot the ends.
larry
   / Man Killed Pulling a Log #13
HENRICO COUNTY, Va. (WTVR) Neighbors are reeling after learning that a man died helping a friend try to remove a tree in after last weekendç—´ powerful storms.
In a community still recovering from the damage, people pitched in to help each other in the 8700 block of Pine Top Drive in northern Henrico county.
Friends said Robert 鉄hane Wade was helping a friend remove a tree Monday when the accident happened.
Renee Raymond, who rents the house where it took place, said Wade and a friend wrapped a chain around a tree stump and then hooked it up to a pickup truck.
Raymond said Wade was standing inside the fence line when the pickup truck accelerated, the chain snapped and unraveled striking Wade in the face.
Police said Wade was rushed to the hospital, where he later died.
Raymond said Wade was a father of six-year-old girl and three-month-old baby.
Wadeç—´ brother, Bryan, told CBS 6 News Angela Pellerano that he was working on funeral arrangements.
çš„ have sympathy for the family. My heart really goes out to them, said John Allen, who lives in the neighborhood where the accident happened.
Allen said he hopes Wadeç—´ family can find comfort in knowing that he died helping someone.
展eæ±*e all going to die some day. But, if the way I go is helping someone else, it値l be a little easier for my family to accept, said Allen.
   / Man Killed Pulling a Log #14
It seems to me that two safety precautions could have prevented this incident. First, bystanders could always stand at least a full chain's length away, and preferably two chain's lengths away from both ends of the chain (which will form the axis of the broken chain's rotation). Second, it sounds like the chain was tensioned suddenly by the accelerating truck. Is it ever safe to do this? I thought chains were always supposed to be tensioned slowly, and only snatch-straps were supposed to be jerked.
   / Man Killed Pulling a Log #15
I have broken one of the 3 inch wide recovery straps and it hit the tailgate hard enough to leave a 2 inch deep dent with the woven impression from the strap in it so I think it would have done alot if damage to a person.
   / Man Killed Pulling a Log #16
On top of that, it sounds like they were trying to pull out a stump, which is generally futile unless it has already been dug most of the way out. It doesn't feel right to criticize in this situation, but my guess is that this was probably an unsafe operation all the way around. I have done a lot of tree work with tree pros, and I can tell you that they are very careful and deliberate, almost delicate, in their work.
   / Man Killed Pulling a Log #17
Agreed all around. The experts are experts for a reason, and that's usually due in part to their respect for the work. Also, one sentence says tree, the next says stump. We don't know exactly what it is that they were trying to do.
Was the chain being slowly tensioned, or was this a "hold my beer..." thing?
We don't know.
It was unfortunate, and we can all learn from it to generally be safer by better respecting the process.
   / Man Killed Pulling a Log #18
While not an expert, I think any recovery operation that requires some kind of jerking motion is inherently unsafe. If your setup requires a running start by the recovery vehicle, it's time to get a different setup. If you watch recovery professionals, it's always smooth, steady tension.
   / Man Killed Pulling a Log #19
unfortunately they rarely give any details. What shape was the chain in? Did they use a chain as well as a rope or strap? People often forget the physics when doing stuff like this. If they managed to move the stump slightly now they've transferred energy into the stump. If the hook breaks that stump will want to roll back into it's hole and it will send the chain flying and not straight at the truck. As it unwinds it's going to swing a giant arc.
I once watched a guy put a hole in the middle of his tailgate when he hooked a tire to the receiver hitch and wrapped a chain around the tire and hooked the chain to a stuck vehicle. His thought was the tire would dampen the shock once the chain tightened. Once he yanked the slack out of the chain he ripped the shock off the stuck vehicle and turned it into a missile.
   / Man Killed Pulling a Log #20
In this example, he probably would have been better off to run the chain through the tire and just let the tire hang off the chain while he pulled.
I also agree with the comments about amateurs trying to jerk a tree stump (or whatever) out. Who knows what kind of chain they were using, too?
BOB
(APPROX. 20) 4' X...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2020 CATERPILLAR 242D3 SKID STEER (A60429)
2020 CATERPILLAR...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
