Rear Blade I nearly forgot. Pictures of my landpride RBT3584
   / I nearly forgot. Pictures of my landpride RBT3584 #1
allen in texas
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
I finally ran out of things to do with the blade. It's been on the tractor since I got it and I need to hook up to the flail. :( So I took a few pics for you guys
new blade 001.jpgnew blade 002.jpgnew blade 003.jpgnew blade 004.jpgnew blade 005.jpg
Three pictures of the blade, a picture of the ditch I cleaned out and a picture of the old blade I struggled with.
   / I nearly forgot. Pictures of my landpride RBT3584 #2
Now that's a SERIOUS blade hanging off the back there, but...... how in the world could you have done any work with it??? Those tires look BRAND NEW, you can still see the webbing between the lugs!!! :laughing: JK'ing there.
Tractor is pretty new, only about 120 hours or so. It used to be a Grand L3240 but I kept feeding it the best oils and fuel I could find and babied it and lo and behold, it grew up into a L5740, just like I had hoped.
   / I nearly forgot. Pictures of my landpride RBT3584 #4
Great blade. I have the same one and have found the skid shoes to be very helpful as well.
   / I nearly forgot. Pictures of my landpride RBT3584 #5
Holy cow! That thing's a beast! :shocked: You're making my poor little tractor with its little tools have an inferiority complex.:ashamed:;)
Joe
   / I nearly forgot. Pictures of my landpride RBT3584 #6
Very nice set up the Hydraulics make all the difference I sure like mine. Great pictures. Good luck.
   / I nearly forgot. Pictures of my landpride RBT3584 #7
Got any more of that magic oil?
You might want to turn the 90s on the swing and angle cylinders to point rearward then run the hoses on top of the main beam. Looks like you have enough hose to do that and would make a cleaner setup.
   / I nearly forgot. Pictures of my landpride RBT3584 #8
Awesome blade,looks like mtnviews i think,from all the work pics ive seen of his I know you won't be dissapointed.
Brian
   / I nearly forgot. Pictures of my landpride RBT3584 #9
Very nice; sure wish I had one.:licking:
Fresh out of the magic oil. I'm looking for another source. :)
As far as the hoses, yes they are a mess but I can't turn the fittings unless I back them out. I was able to turn one fitting on the swing cylinder to the center and made that side a bit better. The others are bottomed out. I AM addressing that, one solution is new fittings and another is to have the hoses remade to the correct length. They are all the same and are what Land Pride provides.
Hmm funny you should bring up something about "neat" ing up the hoses. After all, It is just a rear blade. Now, where did I leave my MeGuire's polish and wax. ;)
CAT930K (A58214)
CAT930K (A58214)
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
WATER TRAILER (A58214)
2011 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A59904)
2011 INTERNATIONAL...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2014 CATERPILLAR...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
