Buying a 135
   / Buying a 135
Went to see thit tractor but the dealer was closed. This is what I found out serial # is 9at22496 trans is 894682m6b hours are 5179. No multi power fenders are rusted pretty bad needs wiring and lots and lots of clean work.Serial # good be 9a722496
   / Buying a 135 #12
According to tractordata.com the serial number (9A122496) you listed is for a 1971 model. I don't believe there was ever a (9A722496) serial number for the Massey 135 tractor, so (9A122496) is assumed. Note that 1's in the serial numbers tend to look like T's. Not having multipower would be a huge plus for me and I wouldn't worry about the rusted fenders because it's probably just cosmetic. If not, replacement fenders are readily available, either new or from a salvage yard. The wiring is also easily repaired using a wiring diagram, also commonly available.
The hours are a little higher than I would like, but that's just my preference. Given the apparent durability of the Perkins diesel engine, some might say that it's just now getting broken in. The big question (how it runs) will be answered after you've had a chance to operate it, check the fluids, etc...
Lastly, the transmission identification number (894682m6b) seems to indicate that it has an 8 speed (4 high/low) transmission, which is also a good thing. IMO
Serial numbers from: TractorData.com Massey Ferguson 135 tractor information
1964: 641000001
1965: 641001909
1966: 641014871
1967: 9A10001
1968: 9A39836
1969: 9A63158
1970: 9A87325
1971: 9A107519 (to 9A128140)
1972: 9A128141
1973: 9A152025
1974: 9A182761
1975: 9A207681
   / Buying a 135
Thanks Massey, Didn't mean to interupt your thread but I kind of got excited. The wiring on this is a mess, my wife pulled a 110 volt plug from the engine I scratched my head and thought about it and figured it was a block or coolent heater. The under side looked clean rims are rusty and front tires are worn.
   / Buying a 135 #14
No problem. There's nothing wrong with getting excited, we all do it, just try to temper your excitement with wisdom. The front tires and/or rims being shot wouldn't concern me because they're relatively cheap and easy to replace. However, rusty rear rims is cause for concern, depending on how bad they are. Spin in/out rims can cost around $300-$400 each new.
Lastly, you're correct, the AC plug your wife found was probably for a block heater, which is common on diesel engines.
   / Buying a 135 #15
It's easy to rewire a simple tractor like that 135 you're looking at. It helps to have the operator, service and parts manuals.
   / Buying a 135
I have found a service manual on amazon, where do I find owners book and parts book?. Where is good places to find parts?????
   / Buying a 135 #17
I ordered my Massey Ferguson owners manual, service manual, and parts manual from AGCO Publications. Parts manuals may also be viewed for free online at AGCO Parts Books. For more information about the manuals I ordered, see my TBN forum posts below.
http://www.tractorbynet.com/forums/...y-1966-massey-135-tractor-13.html#post2874447
http://www.tractorbynet.com/forums/...y-1966-massey-135-tractor-16.html#post2883334
http://www.tractorbynet.com/forums/...y-1966-massey-135-tractor-15.html#post2881097
Here's a screenshot of my order from AGCO Publications, showing the publication numbers and prices for each manual.
   / Buying a 135
Thank you very much Massey you have been a big help to this pain in the azz.
   / Buying a 135
put an ad in tractor house
   / Buying a 135
Sure wish Mike would reply.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2018 Ram ProMaster City Cargo Van (A51692)
2018 Ram ProMaster...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
70009 (A51691)
70009 (A51691)
