I think I screwed up - Tires R1 vs R4
   / I think I screwed up - Tires R1 vs R4 #11
Bout the only benefit to the R4's is as you mention, FEL work, and if you plan on logging alot, the R4's are a little tougher. But for pulling and field work, you cant beat the R1's.
right you are
R4s are also more stable in the woods, some say they wont rut your lawn quite as bad but with that size tractor its a non-issue as I doubt you had mowing your yard in mind when you bought it lol
   / I think I screwed up - Tires R1 vs R4 #12
I personally would rather have the R4's. They are the best all around general purpose tire. Sounds like you maybe needed to keep the logs from plowing and maybe some ballast. Consider logging equipment tires..like a skidder. Seems they run more of an R4 design for a balance of flotation and weight. Maybe to keep from digging ditches. Plus they get the log ends high and only leave the ends to skid. Less damage to the log and less friction. I have the R4's on my JD 110 TLB and I like them. Sure they spin every now and then but that keeps it fun and interesting! My dad just recently ordered a 5085M with a FEL and he's owned and operated more equipment than you could imagine. He specifically requested the R4's. Not saying they're the best because we all know there's a different tool for every job but just saying we really like them! Don't give up on them too soon! I think you made an educated decision about the FEL work needing R4's. Logs are just a pain for any machine or any tire! Good luck and most importantly be safe!! Somewhere in all that...have fun!
   / I think I screwed up - Tires R1 vs R4 #13
Load the tires, and get the front of the logs off the ground. I skid large logs with my little B2920 with loaded R4 tires no problem.
Are you sure it's a 40 degree slope? That is almost 100% grade, and darn dangerous to be on with a tractor.
   / I think I screwed up - Tires R1 vs R4 #14
It is a 4x4 and I used the differential lock too. The tractor jumped straight up and down while spinning the tires. I'd guess the hills to be in the 40+ ish degree range. I was probably not pulling in a logger approved manner. I wrapped the chain around the logs and attached them to the tractor drawbar using a clevis. The chain was kept short so the logs were less than 5 feet behind the tractor but still plowed into the dirt. I may have done better if I had a three point hitch drawbar to lift like you did.
Maybe I just need to adjust my overall expectations. I was trying to pull 2 12 foot and 1 14 foot log and each were about 19 inches diameter.
The problem I see with using a 3 point hitch drawbar is if you can easily be pulling above center of the rear axle making it easier to flip backwards.
   / I think I screwed up - Tires R1 vs R4 #15
That is definitely a concern. It can be alleviated by running a second safety chain from the choker to the drawbar. That way you use the 3-pt to lift the butt of the log, but the safety chain to the drawbar handles the forward pull and alleviates any "wheelie" types of loads about the axle.
   / I think I screwed up - Tires R1 vs R4 #16
I don't think I'll ever get R4 tires again. They're pretty much good for nothing. A lot like those over/under-double barrel rifle/shotguns. They make terrible rifles and terrible shotguns. There are a few remote cases where they are a good call but few and far between. Like R4s for me. It will be ags or turfs from now on - as it has been since my first set of R4s.
   / I think I screwed up - Tires R1 vs R4 #17
Good for nothing? They are about the best tire choice for loader work, which is why backhoes and other construction equipment comes with variations of that type of tire.
If your just considering turf-friendliness and farm-traction, then the R4s could be considered a mediocre compromise. But there are many other factors to consider.
   / I think I screwed up - Tires R1 vs R4 #18
I'd check your owners manual or with your dealer before adding that many rear wheel weights. I have a 6415 and maximum rear weights is 3 per side.
   / I think I screwed up - Tires R1 vs R4 #19
There are ample threads here on TBN about the pros and cons of each of the three major tread types. No need to rehash these arguments here. Suffice it to say that each tread type has strengths and weaknesses. It'd be a mistake to characterize R4's as just a poor mash-up of Ag or Turf tires, though. They're good at what they're good at--period.
   / I think I screwed up - Tires R1 vs R4 #20
Weighted up and run a little soft R4's work alright. The advantage of r4's is on turf. If you spin you only scuff the grass. R1's are great for traction but just a partial revolution and you have a hole.
R4's of course will stand a lot of abuse.
New Holland WorkMaster 37 (A53317)
New Holland...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
