DavesTractor
Elite Member
I know a guy who has one with a 50'' bucket, the tires are wider than the bucket. I have also seen them at the dealer with a 50'' bucket. Checkout the bucket on this one. Maybe they just changed to 60'' bucket????
Have him measure again. They do not make a 50" bucket that fits a ML115. It will be a 60" bucket. However the point is well taken, if the tractor lifts so much, how about a little deeper and taller bucket? I think the answer lies somewhere between what the marketing people want (big numbers) and what the service people want. The service people do not want any compact tractor running around at 100% duty cycle. So they give you a strong loader, but unless you swap buckets or put forks on it, you will only occasionally use all of it's strength. That is just my conspiracy theory! Just my opinion.
LD1 makes a great point. His tractor lifts everything it needs to everytime. A full bucket of wet dirt or whatever. That is really what is important. The rest is just spreadsheet stuff and bragging rights. Unless LD1 was using forks and moving max capacity pallets or something, what his tractor lifts is entirely adequate.
The other point, if you don't mind me mixing responses to various posts, is that you really do have to check what the specs are measuring. At the pins? At 59"? At full heigth? 500mm forward? It all makes a big difference. I wish there was one standard, and I'd prefer the most usable standard which would be center of bucket lift capacity to 59". How often do you lift a max load from the pivot pins? How often do you lift a max load all the way to the top? So even though Mahindra rates at the pins to max lift heigth, I think there can be a better standard. But getting the marketing folks to all agree on what they may print on their brochures would be near impossible. The best we can hope for is that they will at least describe what they have measured and through what range of motion.
