0w30 vs 5w20
   / 0w30 vs 5w20
i'm running 5w40 in my diesels...
   / 0w30 vs 5w20 #22
If you are in a really hot area where there is no benefit to the lower first number, my vote would be to use the higher first number.
Engines like to operate above 200 degrees oil temp. Even in WARM climates, those 60 and 70 degree mornings are "cold" to your engine.
   / 0w30 vs 5w20 #23
I have been running 5w40 or 0w40 oils in my trucks and tractors for years with no problems. I do UOA every change as well. I don't need to do the UOA ever change but I kinda like to look at the oil report. :D
It does get cold enough in my area to hook up the truck's engine block heater. That heater pulls some power, 1,500 watts for at LEAST three hours, to warm the oil. That is 4,500 watts or 4.5 KWH. 4.5 KWH at 10 cents a KWH is 45 cents to warm up the truck. Which adds up to at least $9 to warm up the truck for a month. Say four months of warming is a minimum of $36. $36 is close to what I have to pay for 0w40/5w40 oil compared to 15w40 oil. With the 0w40 or 5w40 oils I don't have to use the engine block heater which saves time and money. Though I do miss having the truck cab warm up quicker in the morning. :laughing: I have seen a 2-3% increase in MPG as well which is not a big savings but it is something. With my driving, I can run the oil about 2.5 times over the recommended oil change mileage. UOA says to change out the oil at around the 2.5x mark. The UOA says my engine is wearing at very low levels compared to other engines of the same type.
Later,
Dan
   / 0w30 vs 5w20 #24
Later,
Dan
And the answer to having a warm vehicle each and every morning can be found here: How to Remote-Start a Car | eHow.com
   / 0w30 vs 5w20 #27
Polaris has an oil that is a 0W40 full synthetic... I put that stuff in everything... my small engines anyway. I do not change them often... sometimes they go for years between changes... have yet to have any issues... no engine failures, leaks, smoking, etc.. One of my B&S 2 cylinders has over 300 hours on it... Maybe its luck.. i dont know.. but its working.
My wifes Mazda CX-9 (ford engine) calls for 5-20... I am jsut running Valvoline in it... but I have never liked the mechanical noise it makes...
   / 0w30 vs 5w20 #28
Actually, PS4 is a 2W50, that is what Polaris claims it to be anyway.
   / 0w30 vs 5w20 #29
I use motorcraft 5W20 synthetic blend oil and motorcraft filters, 05 taurus 270k, 07 F250 110k, 01 F150 102k:thumbsup:
Dave
KUBOTA KX057-5 EXCAVATOR (A52707)
KUBOTA KX057-5...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
1421 (A57192)
1421 (A57192)
