0w30 vs 5w20
   / 0w30 vs 5w20 #31
Correct
:thumbsup:
Lower first number is ALWAYS better.
Unless for some reason you want the oil THAT much thicker when cold:confused2:
Not trying to start a fight.No trolling at all. Just pointing out that your opening statement is wrong. Don't want readers to take conditional conclusions as broad based fact. There's a lot of mis-information on the net.
for your statement to have even a chance of being true, you would have to narrow it down to full synthetic only.
And then you would have to narrow it down to applictations that have short run times and frequent start ups.
   / 0w30 vs 5w20 #32
Not trying to start a fight.No trolling at all. Just pointing out that your opening statement is wrong. Don't want readers to take conditional conclusions as broad based fact. Ther's a lot of mis information on the net.
Do you care to share you opinion on why the lower number is not better?? Because comming on here and just simply stating "wrong" to a comment from another member, with no explination, and without trying to "make your case" is the definition of trolling to a TEE.
   / 0w30 vs 5w20 #33
I actually think you are trying to start something, since you intentionally left of my second paragraph.
I'm not going to copy and paste oil theroy to fight with you. I suggest you google about "making the spread" , or about polymer modifiers or whatever. I guess you think everyone in the world is stupid who either makes or uses straight weight lubes, or lubes that have close spreads? Have you ever heard of machines that run 24/7?
Weekend warrier chinese tractor result don't mean that's what is good for all applications
Here's a spoilier. Conventional Straight wt 30 outlasts 10w30. 10w30 outlasts 5w30. Nuff said.
Your experience with lubes for a seasonal non-pro application don't apply for eveyone.
Opps.. I have to edit this here and add a smiley face, otherwise some folks might think I was getting too serious:)
   / 0w30 vs 5w20 #34
No I did not intentionally leave out your second paragraph. Infact, I quoted your WHOLE post. And I also notice that you edited your post at the SAME time mine was posted. Since it takes me a few minutes to type, I actually hit the quote button on you BEFORE you edited. Perhaps you were editing and adding at the same time I was posting??? Maybe the crossed in cyber-space:confused3:
BUT...you do make a valid point. For something that runs 24/7 and at a CONSTANT temperature, a straight weight oil is indeed best. BUT, since we are on a "weekend-warrior" tractor forum, and we are talking about trucks and tractors, maybe I made an error in "assuming" what we were talking about.
Let me clarify: for 90% of us here, that start a vehicle twice or more a day (once to and once from work), or a tractor several times a day, lower start-up weight oil is best IMO. Even on 10k intervals with synthetic oil, the viscosity modifier additives are far from being worn out when we are changing out oil.
And my tractor is Korean BTW....NOT Chinese:D
   / 0w30 vs 5w20 #35
And the answer to having a warm vehicle each and every morning can be found here: How to Remote-Start a Car | eHow.com
A remote starter costs money. Running a engine and not driving cost more money. :laughing: I can wait 5 minutes before the truck warms up. The kids complain but I figure it makes them tougher! :D
Later,
Dan
   / 0w30 vs 5w20 #36
DarkBlack is correct about the lower first number because that is the weight of the base oil. Oversimplified, additives (viscosity modifiers) that make a thinner base oil have similar properties to a thicker oil at higher temperatures are not as good as the thicker base oil while operating at the higher temperatures. That is why the "start frequently" vs "run for a long time" factor is an important criteria in the choice.
If you care to educate yourself further, a good place to start is:
- Bob is the Oil Guy
Sorry about the duplication LD1 - I missed your last post.
   / 0w30 vs 5w20
and if you care to educate yourself further, you might want to look for better info that bob is the oil guy.. :)
   / 0w30 vs 5w20 #39
Are you saying you have been on the site and find the information generally erroneous? If so, what are your sources? I'm open to being educated if you have any recommendations. Or, was your post just for LD1's amusement.
After all, I regularly read Machinery Lubrication, Jason Sowards, Editor-In-Chief, and find that much of the same information can be gleaned from Bob is the Oil Guy. And the latter is easier for most members to access than subscribing to Machinery Lubrication.
   / 0w30 vs 5w20 #40
That is ONLY correct about dino oils. And if you do any reading on oils (and even "bob"), The VI modifiers are NOT the first things that wear out. You should be changing your oil LONG before the VI additives cause you the problems.
BUT....on synthetic oils like I run, they do NOT use a thinner base oil. The base oil is the SECOND number. So, a 0w30 syn is a 30 base oil and NO Viscosity modifiers. And BTW, I dont think I have ever even seen a 0w30 dino oil.
But either way, I stand by my "lower first # the better" statement. Because your and darkblack's statements about VI modifiers is NOT true with syn oil. And with dino oil, you should be changing LONG before the VI modifiers wear out. IF you run a dino oil and the viscosity modifiers wear out, that is the least of your problems.
2016 MACK PINNACLE (A58214)
2016 MACK PINNACLE...
1997 Generac T/A Towable 175kW Diesel Generator (A56857)
1997 Generac T/A...
New/Unused 20 Ton Hydraulic Jack (A57454)
New/Unused 20 Ton...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58216)
2014 TIELKE...
TANK MANIFOLD (A58214)
2016 Komatsu PC240 LC-11 Excavator (A59213)
2016 Komatsu PC240...
