Water well questions
   / Water well questions #11
He is going to install a pitcher pump.
Seems to me 1/2" steel pipe would work but it's not going to last as long as rod. Steel pie is cheap steel, it will rust out faster than u think.
Interesting project but it seems a long way around to get useable water. Why not a shallow well pump and do away with all lthe complications and maintenance issues? Just curius as I have done a few things "just for the doing of it".
Harry K
We already have county water...plus I have a machine shop and a bunch of brass stock. Why not?
   / Water well questions #14
I think lehmans the non electric shop has a lot of well replacment parts if you cant fab it they might have it.
   / Water well questions #15
That was my guess :) and a very good reason it is.
Are you also fabricating the pump jack? I googled for some and was rather shocked at the high prices and complicated construction. Far far above the one we used with a gas engine for a couple years.
Harry K
Harry K
Yea, I am going to fabricate the whole outfit. I tested the brass pump cylinder yesterday...works great! Tomorrow I will fabricate the hand pump. They are $400-$600 new :0 and I just can't see paying that much. Once I get the pump installed on the well, I will go ahead and build the pump jack.
-Phillip
   / Water well questions #17
-Phillip
Hand pumps for sure and occasionally pump jacks show up at farm auctions around here - don't bring much unless there is a collector in the crowd.
Harry K
   / Water well questions #18
As others have mentioned, it would be worthwhile to have a water sample tested. No use pumping contaminated water...
I will get it tested but I would bet that the water is good. We,and the well are in a valley and we own the ridge
No place for contamination to come from.
   / Water well questions #20
Please post some pictures of your pump build, it sounds interesting. I would shock the well before using it, just put a half a gallon of bleach down it should kill any bacteria from sitting so long.
2020 Ram Promaster City 1500 Cargo Van (A59230)
2020 Ram Promaster...
Commercial truck Frame with Axle (A59230)
Commercial truck...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
24in pin on tooth excavator bucket (A56438)
24in pin on tooth...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
