how to secure a tractor on a trailer
   / how to secure a tractor on a trailer #21
James150, how do the over the tire straps work on the big rear tires of tractors? Do they wrap far enough around to hold the tractor from slipping out from under them in a crash? I prefer that style for cars and buggies, but haven't used them for tractors.
I thought they might be too short to go around the big tires but the strap is long enough to go all the way around the big back tire and I pull it down far enough that I think even if the tires went flat the straps would still hold. I really like the straps for the convenience factor and I think the chain on the loader gives me some extra insurance. I don't usually trailer it all over all the time, usually back and forth three or four times a year.
Jim
   / how to secure a tractor on a trailer #22
I put clevis on all four corners to make it easier to hook to.. I trailer mine everytime I use it..
Andy, I really like your idea, and I'm pretty sure I can find some secure points on my tractor to do the same. One question: how do you attach the chain to the clevis? Do you set the hook on the clevis itself, or do you... I don't know... pass the hook through the clevis and hook it back to the chain? If I have a grab hook, can I just put it through the clevis and call it done?
   / how to secure a tractor on a trailer #23
When chaining to all 4 corners of a tractor, what length chain do you use? It seems like 20' is too long and will leave you with a lot of left over chain to deal with. Of course, too short is worse. What length do you use?
   / how to secure a tractor on a trailer #24
I have a 20' chain that I cut in half and could use with a pair of binders. You could also hook one end to each side of the trailer, then hook a binder near the middle of the chain and onto each side of the tractor (with some slack between the binders). That way you retain the full length of chain, but have the protection of using multiple chains.
Aaron Z
   / how to secure a tractor on a trailer #25
I bought 2 20' 5/16" gold chains at Lowes and had them cut it into 2 10' lengths each and then bought hooks for the cut ends. It works great.
Chris
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500...
Metal American Flag Wall Art (A55853)
Metal American...
UNUSED FUTURE (100) PIECES OF 12'X3' GALVALUME (A57193)
UNUSED FUTURE...
CAT 308CR (A53317)
CAT 308CR (A53317)
2015 Ford F-450 9ft Utility Flatbed Truck (A55852)
2015 Ford F-450...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
