Ruined my PTO Shaft
   / Ruined my PTO Shaft #11
I messed up and cut my PTO shaft off, too short. I have a Woods RM360 mower. Will other brands of PTO shafts work with my mower?
Sorry to hear about your problem. Please review this from Everything Attachments before taking a saw to your new PTO Shaft. How to Measure and Cut a Tractor PTO Shaft - YouTube
You could also measure your old PTO Shaft after viewing the video and ascertaining what the correct length should be, then as has been suggested check to see if an extension is available without buying a complete new shaft.
   / Ruined my PTO Shaft #12
I have welded one back together for my Dad. Luckily it was a square shaft so I could clamp it into a heave angle iron jig to keep it straight while I welded it. Lots of quick welds with cooling time between welds to keep distortion to a minimum. I am not sure I would recommend doing this but it did work.
   / Ruined my PTO Shaft #15
this video is what i did to mine. i think measuring from the end of the tractor shaft instead of the center of the lock like he did on the tiller is the reason for more than one measure four times and cut it short once.
lol
   / Ruined my PTO Shaft #16
so.. what was the outcome?
new shaft.. remade shaft.. extension?
   / Ruined my PTO Shaft #17
just did it last night. i have decided to purchase the ASC adapter if am not happy with that i will replace them with the parts that i cut off. they are both 2" longer than what is in there now.
   / Ruined my PTO Shaft #18
if your issue was just 2" that should be fine..
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2012 JOHN DEERE  624K WHEEL LOADER (A55745)
2012 JOHN DEERE...
2006 INTERNATIONAL 9400I DAYCAB (A55745)
2006 INTERNATIONAL...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
CATERPILLAR 631G MOTOR SCRAPER (A52706)
CATERPILLAR 631G...
