Grease Gun Stuck to Zerks
   / Grease Gun Stuck to Zerks #21
I've never heard of them being called zerks before. I've previously only heard them referred to as grease nipples.
Grease fitting - Wikipedia, the free encyclopedia
A grease fitting, grease nipple, Zerk fitting, or Alemite fitting is a metal fitting used in mechanical systems to feed lubricants, usually lubricating grease, into a bearing under moderate to high pressure using a grease gun.
The patent for the Zerk fitting was granted to Oscar U. Zerk in January 1929, and the assignee was the Alemite Manufacturing Corporation (thus the eponymous names for the fittings). Today many companies make these grease fittings.
   / Grease Gun Stuck to Zerks #22
History
The patent for the Zerk fitting was granted to Oscar U. Zerk in January 1929, and the assignee was the Alemite Manufacturing Corporation[1] (thus the eponymous names for the fittings). Today many companies make these grease fittings.
Before Zerk fittings existed, bearings were lubricated in various other ways that tended to be more maintenance-intensive and often provided less effective lubrication. For example, a typical machinery bearing of the 19th and early 20th centuries was a plain bearing with a cross-drilled hole to receive oil or grease, with no clever fitting at its mouth. Often lubricant was delivered under no more pressure than gravity or a finger push might provide. For example, oil was gravity-fed into the hole, or grease was pushed in. Grease guns to feed the grease with higher pressure existed,[1] but they lacked any fitting to make clean, sealed contact easily, and they were less widely used than today.
The oil hole or grease hole was usually covered with a cap of some kind to keep dirt out, from a simple plug or screw to a spring-loaded hinged cap. The standard mode of maintenance was to have each machine's operator, or a dedicated oiler, go around adding a small squirt of oil or blob of grease to each and every hole on a frequent basis.
   / Grease Gun Stuck to Zerks #23
whoops.. guess it would help if I would read the previous post.:)
James K0UA
   / Grease Gun Stuck to Zerks #24
Thanks for the extra info! I did manage to actually twist the zerk completely out of the threads in cast iron. They weren't good threads to begin with evidently since I should have been able to snap the zerk off entirely well before this. I just hope I can force an odd sized slightly larger metric thread into the hole and be done with it. If not I'll just try some jbweld and chase the threads with a pipe tap.
And for a little trivia to add to your day...
And machines back in "the day" were so often open framed (no enclosed crankcase or valve train) and enormous (think engines in ships, trains, mills, factories) that the "dedicated oiler" was often the littlest guy on the team who acrobated in and out of the works with an oil can in hand to hit all the journals and fittings.
And the "Grease Monkey" came to be.
Ouch. Anybody else remember the Steve Mcqueen "Sand Pebbles" scene where the head engine-room "coolie" got squished?
   / Grease Gun Stuck to Zerks #25
   / Grease Gun Stuck to Zerks #26
Thanks for all the info! I stopped at NAPA for a handful of replacements and came away with these for a try since I wasn't looking forward to tapping, coiling, epoxying, etc...
Part Number: BK 7151049
Product Line: Balkamp
Attributes:
Grease Fitting Specifications : 1/4" Straight Drive Type Fitting, 35/64" Overall Length
Package Contents : (5) Ball Check Fittings Sold By The Each
Just chase the hole with a 1/4 drill and drive them home with a deepwell socket and heavy hammer. Works just fine for this basement shop tool they're on.
At another forum discussing grease fittings there was some debate about how to remove these pressed in ones. Many suggestions of heating the case, sawing off the head and ez-outing, removing the assembly/shaft/bearing and cutting the head off and then driving it through with a punch..... may I suggest the following tool for such a job and 1001 others.....
Just a wide jaw vise grip with a two to three foot 3/8 inch threaded rod replacing the adjustment screw. The slide can be from any heavy metal you can drill a hole through or just get a cheap slide hammer from Harbor freight and use the weight from it.
I love this tool. I've used it for tiny intricate jobs, up to janking and pulling just about anything from hard to get at nails to bearing races. Use it in demolition work when trying to be selective in damage to surrounding material. ETc etc. Grab the head of the pressed in fitting and tap it back out pretty easily with this.
   / Grease Gun Stuck to Zerks #27
Attributes:
While the taps-ins are avail, it's hard to beat the durability of a grease fitting that is threaded in......easier to replace and will withstand high pressures of most grease guns (10,000psi)
Manufacturers love them cuz it eliminates the threading of the housing, but they don't hold up if the grease gets plugged and you are honking on the handle of your grease gun and the fitting pops out....:thumbdown:
I know you said you didn't want to go through the drilling and tapping but you need to consider the pressures grease fittings see......if it taps in easy, it'll pop out easy too
   / Grease Gun Stuck to Zerks #28
I'll second the plugged fitting comment, I've got guns that have never been adjusted in 30 years and they would get stuck constantly on my Kubota's loader fittings. Its all the ones that take grease hard and yes I broke one off, not big deal as I keep a full selection of metric and sae zerks in the shop. I've managed to keep them free flowing since except the lower bucket ones as they get dirty constantly.
   / Grease Gun Stuck to Zerks #29
   / Grease Gun Stuck to Zerks #30
Hope it's not in terribly bad form to resurrect such an old thread. But if anyone else comes in here searching the same problem I'll add what I hope is useful info.
I got here from a google search "stuck zerk". Thanks for the info. Someone pointed out at another board that when this does happen, and since it does not happen consistently even with the same gun, it is likely an indication that pressure is going unrelieved beyond the gun's coupler itself. That's either a clogged zerk, very bad news since you're not getting any grease where you wanted it, you need to remove the zerk and clean/unclog it........ or it's simply a very tight bearing that does not provide any egress of the old grease while you're pressing in the new.
The latter was the case in my situation. I replaced a shaft and bronze bushing. There is a zerk on the arbor and a hole drilled in the bushing. The bushings needed honing after pressing into the arbors and the shaft was a close fit. This situation required very significant pressure from the gun to get grease into the bushing. If I'd known what was happening I might have simply loosened the barrel/coupler on the gun tip to relieve the pressure. Instead I got so angry that I took a wrench to the gun tip and snapped off the dang zerk fitting. Much swearing and throwing of tools ensued:)
I like your avatar. Are you from Czech Rep?
   / Grease Gun Stuck to Zerks #31
   / Grease Gun Stuck to Zerks #33
No, I'm born and raised in the U.S. Traveled quite a bit but never been to the Czech Republic.
Someday I'm certain to try though.
A society that would elevate the "Good Soldier Svejk" into iconic hero status must be pretty interesting. Admirable.
Nothing against "Dirty" Harry Callahan and John Rambo, I am a Yank after all;)
   / Grease Gun Stuck to Zerks #34
So how did you come up with the avatar and screen name? Did you read the book? Is there English translation? If there is an English translation I need to get it for my wife.
I was born and raised in Czechoslovakia but immigrated to the USA 26 years ago. Yes. Svejk is a national icon. His personality describes the national attitude quite well. It served the nation well when it was dominated by Germans, Austrians and recently by Russians. Czech Republic is great country to visit.
   / Grease Gun Stuck to Zerks #35
I use a pneumatic grease gun. I used to have the same problem...the GG tip getting stuck on the zerk despite adjustments. It pulled out some zerks and drove me crazy. Now I change out tips ($4.95 @ TSC) every year or so and have few problems.
   / Grease Gun Stuck to Zerks #36
I have the same problem with mine. It got stuck so bad on loader I did not think it would ever come off. It pulled a fitting out the deck whell on the BX. I have to use a needle point adaptor.
   / Grease Gun Stuck to Zerks #37
Speaking of plugged or gunked up grease fittings, could this be from incompatible greases? And speaking of greases, I have been wondering the best way to lube new to me (used) equipment with new style grease. I just pump the snot out of the fittings until I see only the new grease color coming out. Seems to be a waste but I have heard bad things about some grease mixtures.
   / Grease Gun Stuck to Zerks #38
If you take the zerk coupler apart you will see there is a rubber piston that pushes on and closes the jaws around the zerk head. To release the zerk coupler you have to push on it axially to move the piston back and release the jaws. Then pull the coupler from the zerk. If the zerk is plugged or the pin is too tight (the coupler remains pressurized) it will take quite high force to push the piston back and release the jaws.
   / Grease Gun Stuck to Zerks #39
****apologies for a little PM'ing here in the thread. Hope y'all don't mind.
You definitely need to get the book for your wife. I discovered it left behind on a bookshelf in a house I moved into twenty years ago and just thought "what the heck" and sat down to check out the first pages. I read right through dinner and into the night. There are two or three english translations. Go to the library and grab what they have. The first translation from the 30's is considered poor so skip it if you have a choice. Somewhere I read that a fourth translation is being done which is expected to be very very good.
You can read more on the book here....
The Good Soldier
The avatar is from Google image for "svejk". Illustrations from one of the editions. Svejkovat is just the verb (infinitive) "to Svejk", to act like Svejk or to do something he might do. Apparently it's slang that only a native speaker would understand. "Svejk" ends up being common enough that it's often taken when signing up for forums and emails so I looked the name up and discovered "Svejkovat".
I was in the USAF for six years. Can't describe exactly why I connected so well with the character Svejk. (ok, I'm 3/4 Polish... who am I kidding?) I was a model soldier with excellent reports and honorable discharge, but I admired his gift for somehow surviving absurdity, fanatical patriotism, and frequently pointless acts of war, without the least damage to himself or others, mentally or physically.
There have been paler comic versions of him more familiar to us, like Gomer Pyle, Sad Sack, Barney Fife, etc... but Svejk was a waaaay more interesting original. He's possibly an idiot savant (you're never sure).... the others are just idiots.
Thanks, you've inspired me to get a bit more serious about visiting that part of Europe. Love to spend some time motorcycling through the former eastern blocs.
   / Grease Gun Stuck to Zerks #40
The Good Soldier
I was in the USAF for six years. Can't describe exactly why I connected so well with the character Svejk. I was a model soldier with excellent reports and honorable discharge, but I related to his gift for somehow surviving absurdity, fanatical patriotism, and frequently pointless acts of war, without the least damage to himself or others, mentally or physically.
I am glad you liked the book. I will definitely get the book for my wife. The illustration (your avatar) is from cartoonist Josef Lada.
The Czech idea of surviving hard times is not about fighting and die in the process. Surviving is the victory. Svejk was master survivalist.
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
