fuel consumption 5000 series tractors
   / fuel consumption 5000 series tractors #31
:rofl:
My 5101 must be a toy. I don't start it up in the shop, throttle up to 2400 rpm and pull a 18' disc harrow for 14 hours straight (mfwd engaged and the PTO on just to be sure the neighbors know I'm serious).
Can you help me calculate how much money I'm wasting when running at 1.4 gph versus your $150/ day?
Why are you driving around with the PTO on when you dont even need it? :confused3:
   / fuel consumption 5000 series tractors #32
I believe that is called exaggeration for emphasise. The man clearly has a bright future in politics.
   / fuel consumption 5000 series tractors #33
Maybe there is something wrong with mine if I am going through so much fuel? With an 8' heavy duty rotary mower at 5mph I burn about 3gal/hr, with a 9' flail mower conditioner at 8mph I use 5gal/hr, just tedding hay I am using over 2! If all of you are doing much better then this maybe I should visit the dealer.
Wow they Tedded 12 acres twice last week and raked 8 of them, 4 acres gets raked tomorrow, she put it up to 3/4 of a tank and it's sitting on 5/8 of a tank right now.
which tractor grateful? 5cyl 5065M?
   / fuel consumption 5000 series tractors #35
JD 5303 MWFD, JD MX6 cutter. Ran approximately 5 hrs at PTO rated speed(2400 RPM). Appears that I have used roughly 10 gallons of fuel. This equates to 2 gallons/hr. The tractordata.com site shows 3.6 gallons/hr. Could be the traveling from site to site not mowing that improved the efficiency.
Killbros 260 Seed Conveyor (A57024)
Killbros 260 Seed...
2014 Nissan Rogue Select SUV (A55853)
2014 Nissan Rogue...
2018 JLG 2632ES 26ft Electric Scissor Lift (A53421)
2018 JLG 2632ES...
2011 UTILITY 53FT REEFER TRAILER (A56138)
2011 UTILITY 53FT...
2007 International 4300 Dump Truck (A51692)
2007 International...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
