fuel consumption 5000 series tractors
   / fuel consumption 5000 series tractors #31
:rofl:
My 5101 must be a toy. I don't start it up in the shop, throttle up to 2400 rpm and pull a 18' disc harrow for 14 hours straight (mfwd engaged and the PTO on just to be sure the neighbors know I'm serious).
Can you help me calculate how much money I'm wasting when running at 1.4 gph versus your $150/ day?
Why are you driving around with the PTO on when you dont even need it? :confused3:
   / fuel consumption 5000 series tractors #32
I believe that is called exaggeration for emphasise. The man clearly has a bright future in politics.
   / fuel consumption 5000 series tractors #33
Maybe there is something wrong with mine if I am going through so much fuel? With an 8' heavy duty rotary mower at 5mph I burn about 3gal/hr, with a 9' flail mower conditioner at 8mph I use 5gal/hr, just tedding hay I am using over 2! If all of you are doing much better then this maybe I should visit the dealer.
Wow they Tedded 12 acres twice last week and raked 8 of them, 4 acres gets raked tomorrow, she put it up to 3/4 of a tank and it's sitting on 5/8 of a tank right now.
which tractor grateful? 5cyl 5065M?
   / fuel consumption 5000 series tractors #35
JD 5303 MWFD, JD MX6 cutter. Ran approximately 5 hrs at PTO rated speed(2400 RPM). Appears that I have used roughly 10 gallons of fuel. This equates to 2 gallons/hr. The tractordata.com site shows 3.6 gallons/hr. Could be the traveling from site to site not mowing that improved the efficiency.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2016 John Deere 326E (A47477)
2016 John Deere...
23311 (A51694)
23311 (A51694)
