135 drain hole dripping oil, aft of block with cotter pin, help
   / 135 drain hole dripping oil, aft of block with cotter pin, help #11
you guys are forgetting that that hole is ALSO there to drain oil from the trans input shaft seal.. not JUST the rear main.....
Good point, not often talked about.
I'm not sure what you mean Joe by the two mixing, it's a dry housing.
   / 135 drain hole dripping oil, aft of block with cotter pin, help #12
yep.. often a 4$ input shaft seal and a gasket.. and some will not repalce it on a 150-500+ $ clutch job.
as for the mixing.. I'm not sure what he's talking about either. as you point out.. this is the cry cavity of the clutch bennhouing. not like its a seal between crankcase oil and trans oil.. etc...????
Thank you guys. It is not pouring out, just some drops on the ground. But, I have a couple places that leak (drops on the ground). It really drops after use. I can't thank you enough for the help, being new to tractors and the 135, you guys are a great resource.
   / 135 drain hole dripping oil, aft of block with cotter pin, help #14
Agreed. Maybe one of those seals or both of them are bad. Regardless the OP has a fun :eek: job ahead of him.
   / 135 drain hole dripping oil, aft of block with cotter pin, help #15
Soundguy said:
prevent them from mixing?
Engine oil doesn't get into the transmission fluid, it drains out the weep hole. Effectively it prevents them from contaminating each other, usually engine oil into the transmission. I have not torn mine down, but this is my understanding, no?
   / 135 drain hole dripping oil, aft of block with cotter pin, help #16
completely wrong.
the rear main seal of the crankcase can leak into the dry area of the clutch bellhousing.
the tranny input shaft seal can leak into the dry area of the clutch bellhousing.
both oils then drain out the weep hole instead of contaminating the clutch.. hopefully.
the tranny is a seperate sump AFT of the dry compartment where the clutch is.
the crankcase is a seperate sump AHEAD of the clutch bellhousing.
   / 135 drain hole dripping oil, aft of block with cotter pin, help #17
Soundguy said:
completely wrong.
Again I have not torn mine down, but if the "dry area of the clutch bell housing" is between the rear main seal in front and the transmission input shaft to the rear and the "dry area" has a weep hole, how is the engine oil going to get into the transmission? Not trying to question, just trying to understand. Never had a reason to tear into mine.
   / 135 drain hole dripping oil, aft of block with cotter pin, help #19
this is getting very complicated,I think i'll go to bed now goodnight.
   / 135 drain hole dripping oil, aft of block with cotter pin, help #20
it CAN'T.. that's my point!!
I never said it could!
YOU'RE post #15 mentioned engine oil contaminating tranny oil.. which.. it CAN't.. that's where the confusion is coming from. :)
John Deere 6120E (A50323)
John Deere 6120E...
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
2012 Buick Enclave Premium SUV (A53117)
2012 Buick Enclave...
2007 John Deere Gator 6x4 Utility Cart (A51691)
2007 John Deere...
Ford Tractor (A50120)
