0w30 vs 5w20
   / 0w30 vs 5w20 #71
Regardless of oil weights (viscosity), it's worth mentioning that some premature engine failures (especially in older engines) have been attributed to reduced levels of Zinc, Phosphorus, and ZDDP (Zinc dialyldithiophosphate) in modern oils. All thanks to the EPA.
If it's an "older" engine is it really a premature failure?:)
   / 0w30 vs 5w20 #72
Good question, Who's to say what went wrong and why?
   / 0w30 vs 5w20 #75
Well, regarding the "Lower is better" for the first number, that's not totally true. In my air cooled engines (Generators, motorcycles, UTVs etc) they generally want a single grade oil (usually 30). I called a Honda once about this and asked why SAE30 was better than 0W30 or 5W30 and they told me, the Honda air cooled engine will consume multigrade oil MUCH faster than single grade oil. We do not recommend multigrade oil unless you are operating in equipment in low (under 30F) conditions.
You also have to remember that oil in an air cooled engine will heat up much quicker than oil in, say a car or truck. Also a number of air cooled engines don't usually have oil ports or even a pump so the reduced flow of the non multi weight oil is not as much of an issue. In fact my small 35 cc Honda 4 stroke string trimmer actually vaporizes the oil which allows the engine to be ran in any position.
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
Unverferth Road Runner Head Cart (A59814)
Unverferth Road...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
2007 Hyster S30FT 3,000lb. LP Forklift (A60460)
2007 Hyster S30FT...
