How to build a hydraulic system for 20 ton log splitter
/ How to build a hydraulic system for 20 ton log splitter #1
chandra007
chennai
farmtrac
Hi everybody,
I am building hydraulic system for 20 ton log splitter.
I am interesting to know,how to calculate system requirements.
like engine power,hydraulic pump specifications and hydraulic cylinder specifications.
I am doing some calculations using Force/Area=Pressure
20,000*2.2*4/3.14* d*d.
I am unable to size hydraulic pump.how to get the displacement and flow rate generated by the pump.
Hydraulic tank capacity.some body mentioned spool valve as direction control valve.
how the learned one will approach a hydraulic system building procedure.??
please give some idea to better understand the hydraulics using in any system.
i am thinking like "preparing input for desired out put.
Thanks in advance.
chandra
/ How to build a hydraulic system for 20 ton log splitter #2
Hi bruce,
Thank for that link.
Pumping = 1 Hp = 1 GPM x 1500 Psi
(linear relationship i.e. 2 GPM @ 1500 Psi = 2 Hp
what is the meaning of this?
Engine speed will be same as hydraulic pump speed,if use coupling in between them?
oil flow rate will be same through out the circuit.?
restriction of flow generates pressure,for doing various operations various pressures are required like pushing cylinder and lifting cylinder.
how to adjust pressure ,(based on maximum pressure required for doing one operation?)
please give some idea.
chandra
Thank u bruce lee:)
chandra
/ How to build a hydraulic system for 20 ton log splitter #6
Cylinder bore size x pressure = tonnage.
Pump gpm x at rated rpm = speed.
Gpm x pressure = hp required.
Most advertized tonnage ratings of splitters are BS.
4"BORE @3000 PSI =18.8 TONS
4.5"BORE@3000 PSI =23.8 TONS
5"BORE@3000 PSI =29.4 TONS
Cycle times for 24" stroke at rated rpm.
11gpm ,4"bore =12.3 seconds
11gpm ,4.5"bore =16.2 seconds
11gpm ,5"bore =20.1 seconds
16gpm ,4"bore =8.6 seconds
16gpm ,4.5"bore =11.2 seconds
16gpm ,5"bore =14.2 seconds
Hp required
11gpm 2-stage pump @3000psi -5.5 hp min.
16gpm 2-stage pump @3000psi - 8 hp min.
11gpm 2-stage pump
Log splitter calculations from triptester
Hi trip,
4" cylinder with 24" stroke will have volume of 3.14*2*2*24=301 cu.inch
301/231 gives 1.3 gallons.so it occupies 1.3 gallons of fluid/oil in the cylinder.
if pump supplies a flow of 11 GPM,it can occupy 1.3 gallons*1 min/11gpm=7.09 seconds
So it takes 7.09 seconds to completely move the cylinder to its one end.7.09+7.09=14.18 to complete one cycle.(am i correct?)
if i use 22 gpm pump the cycle time will reduce to half.
for 1 HP engine can produce 1 GPM of pump flow at 1500 psi.
,if i use formula (PSI*GPM)/1714=HP,
1500 PSI*1 GPM/1714=0.875HP(but u mentioned 5.5 HP,i am interesting to know the correction here).
my doubt is about pressure.each pump will have different pressure ratings?or pressure will develop for doing operation.?on factor pressure depends in a system?
"if i use 5"*24"stroke cylinder,22gpm pump,3000 psi pump,13HP engine will be suitable to work with 30 ton log splitter."
If i want to run a conveyor drum using engine ,Hydraulic pump,hydraulic motor,how to size different components.how to find the torque of the conveyor drum?"how can feel that these components? will be sufficient to work with"?
Learned members,please give some inputs.
chandra
Hp required
11gpm 2-stage pump
/ How to build a hydraulic system for 20 ton log splitter #8
Re: Log splitter calculations from triptester
Hi trip,
NO. It takes less fluid to retract the cylinder. Because the cylinder rod occupies volume inside the cylinder, less oil needs pumped. So you have to figure rod volume and take that OUT of the equation for retract.
On the same tolken, retract will also have less power, but will move faster than the extend stroke.
HI LD,
you are right,cylinder volume will be less ,when i consider rod volume.So less fluid is required here in retraction stroke.
chandra
/ How to build a hydraulic system for 20 ton log splitter #10
When using formulas to determine horsepower requirements with 2-stage splitter pumps the fact that the pumps have 2 sections must be considered. The small or low volumne section pumps continuously but the large or high volumne section bypasses at between 600-900 psi.
Many people have found they only needed 500-600 psi to split most of their blocks with a 5" cylinder.
Here is a site for hydraulic caclulators, Baum Hydraulics Corp :: Spec Calculator
/ How to build a hydraulic system for 20 ton log splitter #11
And 2-stage pumps arent good for hydraulic motors (or so I have heard). And if the pump that powers the cylinder for a splitter is going to be the same pump for a motor, now you are talking a 15-20GPM SINGLE stage. and that requires some serious HP.
Hi,
I got some idea to build a log splitter.I am interesting to attach saw to my log splitter,
i need a hydraulic motor to to run the saw?,if yes what capacity hydraulic motor is require,how to split flow for hydraulic cylinder and hydraulic motor.
whether engine capacity is required to improve?extra valves are required?
i have increase pump flow?
thanks in advance.
chandra
Hi,
I am still waiting for your inputs.
I am interesting to know"how to attach hydraulic motor my existing circuit,if i run a saw along with log splitter".
when i am using saw cutter,flow should exists for that.when i am using log splitter ,the saw must be idle,for that what type of hydraulic arrangement is needed.?
it should be some thing like this.
http://www.youtube.com/watch?v=0gdo7WfB90s
what calculations are needed for hydraulic motor input power and out put power?
Thanks in advance
chandra007
/ How to build a hydraulic system for 20 ton log splitter #14
I am not sure but I think that sawblade is driven off the motor and not hydraulics.
I dont really know the calculations you are asking for. But IF you want a hydraulic powered saw blade, you are going to have to either used TWO pumps (a 2-stage for the splitter and a single for the saw)
OR you are going to have to only use a single stage. And using a single stage is going to do one of the two following: 1. Make you have a slow splitter. 2. Make you have to run a larger motor. Like something in the ~20-25HP range for a decient cycle time on the splitter.
Directing flow is all in the valving.
I really dont want to discourage you or anything, but it sounds like you are trying to bite off more than you can chew without a sound understanding of hydraulics.
Maybe others will offer more advise, but this is as far as I want to go. I have never built a processor. So the exact things you are looking for I cant help with.
/ How to build a hydraulic system for 20 ton log splitter #15
You need to do some more homework, and figure out the size blade on the saw, and the rpm for that blade and the size of hyd motor to turn the blade and how many GPM will make it work like you want.
You need hyd flow to the log splitter valve and to the hyd motor. A motor spool valve should run the hyd motor.
One valve should have PB to feed hyd flow to the other valve. Both valves can go in series, as you will using either the saw or the splitter. If you try and use both valves, the first valve will have priority.
For the pump, you need to compute the total GPM needed for both operations.
Then you need to compute the HP necessary to run the pump.
Thanks for your reply. J_J & LD1,
As i am new in the field of hydraulics,i am getting more doubts.
at present i am going through the formulas and understanding the relation between Engine HP,Pressure,flow,RPM ,displacement and torque.
I am trying to use these formulas for real time applications.
J_J sir is giving some idea,how to link formulas with real time applications.I am going through his post,they are more useful.
chandra
/ How to build a hydraulic system for 20 ton log splitter #17
Where is Chennai located?
J_J sir,
chennai located in the south India,comes under the state of tamilnadu.
chennai
/ How to build a hydraulic system for 20 ton log splitter #19
Chennai, India (formerly Madras, renamed in 1996)
Dear all,
i have problem to approach for a problem.
If a hydraulic system is having 1000 psi pressure and the system contains a hydraulic motor to turn a 10 in radius drum at 30 rpm to lift a 1000 lb weight.
How to find out the gpm required by the motor to lift the weight?
torque delivered by the motor?
Chandra007
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2023 Bobcat T595 Compact Track Loader Skid Steer (A64553)
2023 Bobcat T595...
2022 EZ-GO ELITE...
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
UNUSED FUTURE MINI EXCAVATOR RIPPER (A65055)
UNUSED FUTURE MINI...
