Procedure Help. Forest to pasture.
   / Procedure Help. Forest to pasture. #21
You didn't mention if you had stumps to clear. If there are a significant number you might inquire about having someone with a fair sized bulldozer (Cat D-6?) with a rake blade come in and de stump and clear out the "mulch" all in one swoop. Would probably run over a grand but might be cheaper in the long run.
On another note, if you are using your tractor for the work watch out for stumps. They are not friendly to oil pans and hydraulic lines.
   / Procedure Help. Forest to pasture. #22
The problem with using a dozer is you push up all the topsoil with the stumps, making it harder to burn the stumps. With an excavator you can pull the stumps, shake the dirt and topsoil free then stack them for burning. I've burned thousands of stumps over the years, 6 months to a year, mix in some brush and touch them off. What's left can be burried or restacked for the next brush pile burn. I love running a dozer, but using it to deal with stumps leaves you with a pile of stump mixed debris that you have to let rot.
   / Procedure Help. Forest to pasture. #23
I agree, thats why I suggesated a rake blade. We used them years ago to clear fairways for golf courses. Dirt runs thru the tines.
2009 RoadTec RX500 Asphalt Cold Planer Milling Machine (A55787)
2009 RoadTec RX500...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
198367 (A51243)
198367 (A51243)
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
2012 Nissan Altima Sedan (A55758)
2012 Nissan Altima...
