2012 NH Boomer 30 HST or Kioti CK30 HST? Value?
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #242
Thanks, guys. Steve, that BB is only 65" but weighs just under a half ton! I can imagine how thick the steel on that is. My tractor is 3000lbs with 600lbs extra for the loaded rears. Do you think there's a possibility my wheels will just be spinning if the ground is wet and I'm pulling something that heavy along with a load of dirt?
rj, that's the BB in the video on their website. The 5.5ft is much lighter. Is there room for a large rock on top of it?
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #244
Ask Woods or your dealer for a recommendation. I maintain that a 30 HP CUT really doesn't need more than a real standard duty BB weighing a bit over 500lbs.. Woods owns Gannon and uses that brand name for heavy duty BBs.
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #245
Is 65" wider than the tractor?
I believe it was mentioned that my NH is 66" wide. My budget is super tight after the tractor purchase and adding remotes. The Woods seem to be almost twice the price of the EA Xtreme duty. I may take my chances on the lesser BB which, if and when it breaks, can be replaced. The two together would not be much more than the cost of the pricier.
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #247
QUOTE]
The link I put up is for the low back model if look at all of them there is an Lb and hb, low back and high back. I choose the low back model which will carry less dirt because your tractor is a little light. When operating a boxblade I find the weight doesn't have as much effect on traction, that is determined more by how deep you are attempting to cut. Not to say that dropping a boxblade with the rippers down all the way won't stop your tractor, depends on the soil. Where the weight makes a big difference is when you are trying to grade smooth, the small rocks and gravel are pressed down by the heavy blade allowing more uniformity to the surface. With a light blade the gravel can easily allow it to ride up or bounce more readily. Also consider the fact that anytime the box is raised up just a fraction that all of its weight is transferred to the rear wheels for more traction. This boxblade I should mention would require one remote for the scarifiers to work. If you only have two and use topntilt at the same time you would need to unplug the tilt cylinder and use the scarifiers to rip everything up then plug back in the tilt cylinder to do the rest of the finish grading. That is why I suggested getting all the remotes you can.
About the width, I was following your lead on sizing but make sure you can cover your tire tracks, you may have to go wider or adjust the rear wheel width in a tad.
Need to know more specifics on your tractor setup before choosing.
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #248
I pull a 900 lb Gannon, 6' BB. It cuts and levels real nice. I'd also suggest a rake, if your road is stone. Make for easy grooming and crowning without digging too much. If you have ditches to maintain, you'll want a 6 way scraper blade that can be offset. The ones the slide L/R give you the greatest reach to get in ditches while your tractor stays on the road. I wouldn't buy new for any of these. Look on Craigslist. These implements are always for sale. I got my BB for $150 and put another $150 in a new cutting edge for it. Now I've got a BB that would have cost well over $1200 new. I picked up a nice 6' rake with gauge wheels for $250. I did buy my scraper blade new, and spent way too much for it, like $800. Dime a dozen on CL for $100 to $300. You also want a hydraulic top link. Get one now. It's worth every penny.
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #249
I thought that the L/R sliding offset blades usually only went 12"-18". :confused3: Most of the rear blades that have the boom pivot for offset go from 18"-35". If the OP has a lot of road to work-maintain, I highly recommend a rear blade and a land plane grader blade (LPGB) along with the box blade. They each work very well at their intended purposes. but I'm thinking that some of those may need to come at a later date. ;)
   / 2012 NH Boomer 30 HST or Kioti CK30 HST? Value? #250
If you want to go cheap on a box blade your may want to check at tractor supply or whatever your local farm supply store is. I doubt your tractor will hurt any of the cheaper box blades. The heavier ones do a better job grading, they don't create wave like a lighter one. The extra weight is also nice for using the fel. You may want to watch craigslist, you find a deal on a nice used one. I think I would go with a 6' box blade. The Bobcat I had was a similar sized tractor as you NH and it handled it real well.
2013 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2013 Ford F-450...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
