Type A automatic transmission fluid
   / Type A automatic transmission fluid #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
I have an old Massey Ferguson tractor where the hydraulic system for the loader as well as the power steering calls for type A transmission fluid according to the original manuals. Can it be substituted with Dexdron III fluid?
   / Type A automatic transmission fluid #2
you may actually luck up and find some type a from off brand bottelers.. but I see lots of recmendations for the dex III as a repalcementr for the b and older A
   / Type A automatic transmission fluid #3
Yes, I believe so. From ftp://rohan.sdsu.edu/pub/mml/archive/Drivetrain/atf.txt
The A/AQ-ATF/Dexron fluids are BACKWARDS-COMPATIBLE. That means that all
transmissions that called for Type-A, AQ-ATF, Dexron, Dexron II, Dexron
II-d, Dexron II-e, or Dexron III should now be using Dexron III.
If it works in an automatic transmission that originally called for Type A, I have no reason to believe it won't work as a substitute for the Type A fluid your tractor originally called for.
Buck Statue (A55853)
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2014 Ford Escape AWD SUV (A55853)
2014 Ford Escape...
Duetz Power Unit (A50120)
Duetz Power Unit...
Cowboy Wooden Statue (A55853)
Cowboy Wooden...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
