Type A automatic transmission fluid
   / Type A automatic transmission fluid #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
I have an old Massey Ferguson tractor where the hydraulic system for the loader as well as the power steering calls for type A transmission fluid according to the original manuals. Can it be substituted with Dexdron III fluid?
   / Type A automatic transmission fluid #2
you may actually luck up and find some type a from off brand bottelers.. but I see lots of recmendations for the dex III as a repalcementr for the b and older A
   / Type A automatic transmission fluid #3
Yes, I believe so. From ftp://rohan.sdsu.edu/pub/mml/archive/Drivetrain/atf.txt
The A/AQ-ATF/Dexron fluids are BACKWARDS-COMPATIBLE. That means that all
transmissions that called for Type-A, AQ-ATF, Dexron, Dexron II, Dexron
II-d, Dexron II-e, or Dexron III should now be using Dexron III.
If it works in an automatic transmission that originally called for Type A, I have no reason to believe it won't work as a substitute for the Type A fluid your tractor originally called for.
2018 Altec DC1317 Towable Brush Chipper (A55851)
2018 Altec DC1317...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
6' Fork Extensions (A56469)
6' Fork Extensions...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A57024)
2024 BCL...
