CBW1999
- Joined
- May 11, 2008
- Messages
- 832
- Tractor
- Kubota 7510, Toro Groundsmaster 217D
CBW, thanks. As Robert mentioned, it sounds like a whole lot of trouble. I might try it on another very small one, but it sounds like it would be real tough for a big one.I wonder if a pressure washer would work?
You might be onto something there. As long as it isn't a "steam" cleaner. A commercial hot water pressure washer, if the temp can be adjusted but- the key is hot water setting on the hair for minutes to loosen it. I think it would defiantly remove the hair once loosened!
I also like the idea of using burlap to hold the water on the hog longer- probably use a lot less water that way.
We have a couple hogs going to the freezer in October. I'll post some pics/video and try a couple of different ways.
Regarding your B.I.L. wild hog issues. I've heard that some areas down there will butcher and use the meat for the needy. Maybe they would come get them. I agree that this has to be extermination not management based on the destruction they do.
With the number of people raising hogs in Vermont (some with the intent of making fast cash and not using their brains)- it is only a matter of time until we start to have the same problem.
