Buried baling twine... In a grid pattern!
   / Buried baling twine... In a grid pattern! #1
dougb256
Summertown, TN
None
Hi,
Brand new farm owner here. One of our neighbors cuts and bales the hay from our pasture, and we get a percentage of the profits when it is sold.
He recently did the fall cutting, and we had 2 big stands of Johnson grass and unbaled hay left over. He told us that there's baling twine buried in those two spots and it gums up the work on the baler. My wife and I decided to tackle it, and soon we were pulling up hundreds (if not thousands) of yards of red plastic baling twine. It's around 4-6" under the ground, in a grid pattern, approx 1' space in between the rows. We've asked farmers, ranchers and the Amish about it; nobody can figure out.
Right now we still live in the city and go to the farm on the weekends, so we only have 2 days per week to work on it. I still have some clearing to do, but I think we have it under control, at least for the time being.
Any ideas on the baling twine grid pattern?
Thanks,
Doug
   / Buried baling twine... In a grid pattern! #2
No idea about the grid pattern but have to wonder how it can possibly affect his baler if it is in the ground. Unless there are lots of ends showing that the baler will pick up?
   / Buried baling twine... In a grid pattern! #3
Hmmmm. Does the neighbor know how it came to be there?
Yes, that is it - the baler gets a short end that sticks out of the ground, it gets wrapped around the machinery and yanks out another long section in the process. They have just been going around it for what
looks like at least a few years, as the prior owners just let the pasture go.
   / Buried baling twine... In a grid pattern! #6
Net wrap bailing twine. Some one feed a bale and didn't remove warp. Cow/Horse stomped it in the ground as they were eating bale????
Possible, but one area had buried twine approx 30' x 40'. The second area was bigger, maybe 30' x 60'.
   / Buried baling twine... In a grid pattern! #8
Plowed in instead of picked up?
   / Buried baling twine... In a grid pattern! #9
Some sod has a grid pattern plastic type of mesh to it.
   / Buried baling twine... In a grid pattern! #10
i have seen wire, were a hole was dug, and then wire just tossed into hole, and then dirt put back on top of it.
but physically actually laying things out in a grid pattern and put into the ground on purpose... sounds strange.
if it was laying on top of the ground. say from a old vines, or tomato spot, or some other crop that you might want to hang / tie up some what, to make things for easier harvesting... i might buy into that. and last time the spot was used was years ago. and posts rotted away, and then live stock, to tractors just ran everything over. pushing the stuff some what into the ground.
perhaps last owners had some sort of experiment going. and wanted the wired buried for who knows what reason, and used some sort of metal detector? or like to pin point things out on the grid? vs year after year trying to measure things out with a tape measure and string.
1' x 1' grid. perhaps it is a wire mesh. like used in concrete? and they wanted to get ride of it. so dug a very shallow spot and tossed it in, and covered it back up?
   / Buried baling twine... In a grid pattern! #11
Sounds like old stacks of square bales, that rotted down. Bales stacked criss crossed, explains the "grids"..??
   / Buried baling twine... In a grid pattern! #12
Sounds like an excavation grid for an ancient burial grounds.
Now I'm wishing that I had taken some pictures! Not wire, not mesh, but red plastic baling twine. Yards and yards of the stuff. I filled two large trash bags, have another bag to fill. Some pieces are over 50' in length.
   / Buried baling twine... In a grid pattern! #14
Sounds like a job for a Ratchet Rake.
Yes, a Ratchet Rake sure would've been handy! We used a hand rake, gloves, scissors, a Husqvarna trimmer and a push mower. Slow going, but I think we have gotten rid of all that baling twine.
   / Buried baling twine... In a grid pattern! #16
Someone had a large "Square Foot Garden"
Building a Square Foot Garden | Victory or Death in the Kitchen
Square foot gardening - Wikipedia, the free encyclopedia
Really Rose: April 2009
   / Buried baling twine... In a grid pattern! #17
This sounds to be the most logical. Could have been many years back.
   / Buried baling twine... In a grid pattern! #18
Is it hilly It could be some type of erosion control?? most likely net wrap a round bale w/ net wrap cut wrap unroll bale= erosion control
No, it's flat pasture.
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
